RV.Net Open Roads Forum: Forum Posting Help and Support: Travel trailer framing sides
Search only in Forum Posting Help and Support
Open Roads Forum  >  Forum Posting Help and Support
 > Travel trailer framing sides
jimmypiscosouralijo6
94558
Posted: 01/10/19 10:31pm Link  |  Print  |  Notify Moderator
Iam reframing the sides of my travel trailer. Do I need to level the trailer before framing the sides?
2007 alejo
NOTE: Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" located at the top of this forum?
    "Forum Posting Help and Support is reserved for questions on how to post in the forums, signature and photo testing, reporting website or member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, create future threads in the RV FORUM which corresponds to the subject of your topic. Thank-you!"
* This post was edited 01/11/19 02:07pm by an administrator/moderator *
Beverley&Ken
Tottenham,Ontario
Posted: 01/11/19 12:17am Link  |  Print  |  Notify Moderator
I would, just to make the build easier. Using a level to make sure studs/walls are properly squared up and at 90• to the floor. Door framing etc. Yes you could use a 24” carpenter’s square and measure, but also using a level (horizontally and vertically will give easy double checks for square and vertical
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
gbopp
The Keystone State
Posted: 01/11/19 03:57am Link  |  Print  |  Notify Moderator
x2. I think it will be a lot easier and quicker working on a level platform.
valhalla360
No paticular place.
Posted: 01/11/19 06:32am Link  |  Print  |  Notify Moderator
If you want everything square when you are done, it will make it 100 times easier.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
drsteve
Michigan
Posted: 01/11/19 07:10am Link  |  Print  |  Notify Moderator
Yes. It'll be much simpler to get everything plumb and square if you're working with a level platform.
1991 Palomino Filly PUP
ScottG
Bothell Wa.
Posted: 01/11/19 10:58am Link  |  Print  |  Notify Moderator
Yes unless you want to use a carpenters speed square and build everything at a 45 degree angle [emoticon]
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
