RV.Net Open Roads Forum: Class A Motorhomes: CO detector beeping
Open Roads Forum  >  Class A Motorhomes  >  Safety Issues & Recalls
 > CO detector beeping
stickdog
Somewhere, USA
Posted: 01/11/19 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
Ours aged out at 9 years. Replaced with hardwire.
9-11 WE WILL NEVER FORGET!
17 MS 36 RSSB3
Gone 04 HH DA LS 33.5 RLTG
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
Wherever I happen to park
Posted: 01/11/19 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
Some beep because they are old and tired
Some beep because they are hungry and the battery is low
Since yours in in storage.. I'm going with option 2.
Crank up Generator for oh say six hours or hook up to shore power (same time).
Home is where I park it.
ScottG
Bothell Wa.
Posted: 01/11/19 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
Our first one lasted that long but I don't think they last that long anymore or at least, I think they have something in them that makes them age out at 5 years now. The last two I bought seem to die at EXACTLY 5 years.
I'm trying a little experiment with out new trailer. I'm going to disconnect it in the off season (about 4~5 mos a year) and see if it lasts long than 5 years.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
Gundog
Ridgefield, Wa
Posted: 01/11/19 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
It is stored at my house and hooked up to shore power all the time.
2005 34' Expedition Cat C7 Allison 3000
Gundog
Ridgefield, Wa
Posted: 01/12/19 09:47am Link  |  Quote  |  Print  |  Notify Moderator
I checked the date it is a July 2009 so I guess it has lived out its life. The battery charger is on so it is not a battery issue. Thanks Mike
mtofell1
Oregon
Posted: 01/13/19 11:25am Link  |  Quote  |  Print  |  Notify Moderator
I was in a recent continuing ed. class for my trade license and a guy who seemed to know a lot about smoke and CO detectors had some interesting info. For the CO detectors, they start to lose effectiveness after just a few years and by 5 years they should be replaced. This seems especially important given the confined space of an RV and the cold temps the detectors are subjected to.
I personally put both smoke and CO detectors in each area (where doors can close) in my RVs.
Hikerdogs
Wisconsin
Posted: 01/13/19 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
Gundog wrote:
The coach is in storage and not in use but I keep hearing a faint beep I removed it thinking it needed a new battery but it is hard wired. The coach is plugged in and there is nothing running that should trigger the alarm I am guessing it has gone bad. I need to get it fixed we will be using the coach staring the 22nd of this month. The existing detector is a Costar brand.
Should I get another one that is hard wired or a battery operated model?
I don't know where you're located, but It may be too cold for the detector to work properly. Most CO detectors only work within a fairly small temperature range. The widest range I am aware of is from +40*F to 100*F. More often it's +50*F to 100*F
We have one at the family cottage that needs to be unplugged during the winter months. If the temperatures go below 50*F a red light comes on and it starts beeping.
Hikerdogs
2013 Winnebago Adventurer
Fivetwos
NJ
Posted: 01/14/19 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
When you pulled it out did you check the voltage going into the unit? I feel like the best new one is a hardwire with a battery back up...
I've never had a 10, but I have had....
Cocky_Camper
Rock Hill, SC
Posted: 01/15/19 06:11am Link  |  Quote  |  Print  |  Notify Moderator
Ours beeped when it "expired". It started at 1am and beeped about every 5 minutes! We got up and and took if off the wall and replaced it the next morning with the same thing.
2004 Sea Breeze by National RV - 8341
Former Coaches:
2006 Keystone Zeppeline 291 - TT
2000 Aerolite Cub F21 - Hybrid TT
1991 Coleman Pop Up
Formerly known as: hybrid_camper
Gundog
Ridgefield, Wa
Posted: 01/15/19 09:11am Link  |  Quote  |  Print  |  Notify Moderator
Fivetwos wrote:
When you pulled it out did you check the voltage going into the unit? I feel like the best new one is a hardwired with a battery back up...
I have not completely removed it yet it is hanging from the wires still beeping. The coach is parked at the rear of our property under an RV cover. I bought a battery powered one to replace it I just need to cut the old one in the clear they did not leave enough wire to unplug it[emoticon]
