RV.Net Open Roads Forum: Travel Trailers: Flagstaff design harder to tow?
 > Flagstaff design harder to tow?
Fishwater
New Hampshire
Posted: 01/11/19 06:03am Link  |  Quote  |  Print  |  Notify Moderator
We have a 2013 Flagstaff that we purchased brand new to replace our 2009 Passport 290BH. When we bought the camper I had a Dodge Ram half ton thinking that I’d be able to tow the new trailer with but quickly found out that would not be possible. The camper towed terrible on the ride home & I just figured it was due to the additional 1500lbs so it was time to upgrade to a bigger truck. I upgraded to a 6.0l diesel Ford F-350 crew cab thinking no problem, it will tow that camper like it’s not even there. I continued to fight the trailer for the rest of the season.
Half way through the second season I dug deeper into the trailer after continuing to fight with towing in the 1 ton diesel that by all accounts should tow that thing without breaking a sweat. I ended up finding that one of the rear axle brakes was miss adjusted from the factory causing the additional drag on the trailer. Finally! I figured I found my issue! The trailer did tow better but not as well as I hoped, still felt like a giant brick behind the truck. By the end of the second season my 6.0l was getting a little tired so I once again upgraded to a 2013 F-350 crewcab with a 6.7l PSD, once again more than enough to tow the anchor behind us.
Last season went much better, I spent a bunch of time dialing in the Rees strait line that I’ve owned since the Passport, bought a tongue scale (1150lbs on the tongue) & adjusted the hitch multiple times until I got it about as good as I could get it without bringing it to the scales. It’s better but still has a little sway at times, still feels heavier than it should behind the PSD but works. I’ve checked the tire pressure constantly, checked for uneven tire wear indicating a bent or misaligned axle with nothing noticeable, I don’t know of a local or even a semi local place that does HD truck alignment’s but I still wonder if there isn’t an axle issue? I know I should hit the scales but with 2 kids, a full time job traveling & life I really struggle finding the time to drive an hour each way to the scales plus the time there. Forget bringing the family loaded up ready to go camping for that exercise!
This year we are planning to expand our camping area since the kids are getting older but I’m dreading another season fighting the tow every trip. I’m seriously considering downgrading, changing campers, getting something smaller that unfortunately won’t have the storage or quality we’re used to but will be easier to tow. We love the layout of the Flagstaff, I love the quality, it’s one of the best built campers I’ve ever seen. In my previous life I was a service manager at a large RV dealership so I’ve been inside many campers, inspected them, worked on them, pulled many a camper, boats, trailers, etc.
I’m really starting to wonder if there is something inherently wrong with the flat front face design of the Flagstaff units, I see that they have changed them on the new models for better aerodynamics. So anyone have any insight, previous owners who’ve owned one & changed to a different brand with input?
* This post was edited 02/13/19 04:20am by Fishwater *
drsteve
Michigan
Posted: 01/11/19 06:24am Link  |  Quote  |  Print  |  Notify Moderator
A one ton should have no problem pulling that trailer. I doubt aerodynamics is the issue--the angle of the front has little effect on the wind resistance of a TT that size.
I'd find a HD truck/trailer shop and have them check it over.
1991 Palomino Filly PUP
MFL
Midwest
Posted: 01/11/19 06:37am Link  |  Quote  |  Print  |  Notify Moderator
After owning several TTs, which did tow well for me, I switched to fifth wheel models. I do think FW towing is a much better experience. You have enough truck for towing/carrying a FW, so might be something to consider. While current FW is heavier than the previous FW, it is more aerodynamic, and tows just as easily, with about same towing MPG.
I do think aerodynamics has something to do with one towing better than the other. As far as weight, once moving, rolling down the road, 1500 extra lbs, should not be a huge factor. If you had a brake dragging/over tightened, to the point of heavy towing feel, it would have been smoking, lots of stink, so would have been very obvious.
Jerry
donn0128
Pronounced Ore-gun
Posted: 01/11/19 07:03am Link  |  Quote  |  Print  |  Notify Moderator
WOW! Lots to digest. First, you mentioned the hitch is the same as used on last trailer? Is it possible the hitch is not rated high enough?
TT sway is or has always been part of the TT experience. I think at this point in time I would measure hitch to axle distances and see if possibly Lippert welded the axles on wrong.
Fishwater
New Hampshire
Posted: 01/11/19 07:12am Link  |  Quote  |  Print  |  Notify Moderator
Sorry, yes, lots to digest! I've been using this Strait Line for 6 seasons but I did upgrade to 1200lb bars with the new camper due to the increased tongue weight.
DutchmenSport
Over There
Posted: 01/11/19 07:21am Link  |  Quote  |  Print  |  Notify Moderator
Delete
* This post was edited 01/20/19 07:50pm by DutchmenSport *
prichardson
Lafayette, La
Posted: 01/11/19 07:27am Link  |  Quote  |  Print  |  Notify Moderator
There is enough difference between the two in frontal shape to be noticeable when towing, especially at high speed and in head winds. If sway is a problem you may not have enough tongue weight,
shum02
Burlington ON CDA
Posted: 01/11/19 07:29am Link  |  Quote  |  Print  |  Notify Moderator
Alignment could still be off. Lot's of ways to give a basic check of axle alignment on the web without any real tools outside of tape measure. If it's really off it won't take much to know for sure.
My 6.0L would not break a sweat pulling 9000lbs. Presently 17500GCWR right now ready to camp.
2006 F350 Lariat FX4 CC 4x4 PSD
2007 KZ2505QSS-F Outdoorsman
trailer_newbe
Tucson
Posted: 01/11/19 07:34am Link  |  Quote  |  Print  |  Notify Moderator
Max weight on a 2017 Flagstaff is around 9,000 lbs so you should be well within your towing limits. Our trailer tops out at 8,150 and we tow it with a 2018 RAM 3/4 Cummins Turbo Diesel. I feel the trailer for sure but climbing or going down hills is no problem. We just towed to Lost Dutchman in the Superstition Mountains where the winds were 30 MPH. Just slowed to 55 MPH and all good.
What type of mileage are you getting ? What is your expectation towing 9K with the truck you have?
2018 Jayco White Hawk 28RL
George3037
Central Square, NY
Posted: 01/11/19 07:39am Link  |  Quote  |  Print  |  Notify Moderator
By going from a 1/2T gas to a 3/4T diesel as you noted you should not even notice the extra 1500 lbs and it should pull it with ease. I'd guess something must be wrong either with actual loaded weight or the way the hitch is set up. According to the specs I read your loaded weight should be around 8970 lbs and your tongue weight of 1150 is about 13%. In theory the numbers look good. Maybe a trip to the scales is needed to see actual numbers or a good shop to check out the brakes and axles. I'd think you'd noticed if the brakes were dragging by the smell or smoke after a short drive. Check them again as Dutchman said. Its possible a short could be applying the brakes.
I tow a Gulf Stream 28RLR 32.5', spec's say 7180 lb dry, 1030 hitch weight, and max capacity of 11,170. I run a little over 10K loaded, 1250 hitch weight with a 2016 2500HD crew cab 4x4 6.0L gas and 4.10's and haven't noticed the problems you claim to have. Yes, I know my TT is back there but it tows great and doesn't sway.
What rear end gears does the F350 have? if 4.10 or 4.30 should have no problem towing 9K. Hope you get it figured out.
* This post was edited 01/11/19 07:46am by George3037 *
