RV.Net Open Roads Forum: Class C Motorhomes: The sins of the previous owners...
 > The sins of the previous owners...
BillHoughton
West of the Mississippi
Posted: 01/11/19 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
...are visited upon the subsequent owners.
The awning on our Itasca is fastened to brackets that stand it off from the side about an inch at the narrowest, an inch and a half at the widest, and about five inches high. One of the two previous owners - I suspect the original owner - decided to glue some weatherstripping, of the type used to seal car doors, at the bottom of this gap. I'm not sure what the goal was. To keep water from dripping down behind the awning (that you're not supposed to leave open when it rains anyway)? To reduce wind noise?
Whatever the intent, the effect was to trap leaves and other detritus on the gap, which buildup then trapped water. Fortunately, the awning's backplate is aluminum, and the RV in that area is fiberglass and aluminum; so there's no rust-through (there is some rust on the brackets to which the awning gets fastened; I'll need to address that before putting the awning back on).
Removing the weatherstripping took several hours, about an hour of which was dedicated to figuring how to to strip the adhesive off (Goof-off and a sharp, stiff putty knife was the final answer). At least I won't have to do that again.
turbojimmy
New Jersey
Posted: 01/11/19 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
The guy that owned my rig before me (may he rest in peace) must have been related to MacGyver. When replacing my shocks I wondered how the guy managed to get the bolt and nut tightened because you can't even get your hand up in there never mind a socket or wrench.
This is what fell out:
He had wrapped some wire around the nut so he could hold it just tight enough for the lock washer to grab. Clever.
Ever since then I find all sorts of interesting repairs. The best is a $0.50 fly swatter whose handle had been repaired with a stick and electrical tape. I kept it as a reminder of what I'm in for when I come across some of his repairs.
1984 Allegro M-31 (Dead Metal)
BillHoughton
Posted: 01/11/19 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
That one with the wire is pretty clever. I'll have to (try to) remember it.
klutchdust
Orange, California
Posted: 01/11/19 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
My step-son is from Cherokee heritage. he has worn shoes only when he has too.Only man I know that paints 30 feet up on a ladder in bare feet.
Needing to go to Walmart for paint supplies he taped rags on his feet so they would let him in, his rear view mirror is a hand-held girls mirror with sparkles taped to the broken one, his antenna, of course a coat hanger.
I love the guy, his kids call his repairs "jenks" don't know the meaning and hope to not offend anyone.
The wire around the nut is a good one, i have used putty in a box wrench then pushed the nut into that, if need be even used the open end side. In a pinch reach for some grease nearby, maybe from a ball joint or something and use that.
the taping of a 50 cent fly swatter..........geez...
K Charles
Connecticut
Posted: 01/11/19 03:43pm Link  |  Quote  |  Print  |  Notify Moderator
You can buy nuts with the wire already attached.
OH48Lt
Whitehouse, OH
Posted: 01/11/19 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
The wire-wrapped nuts are sometimes used to install trailer hitches onto frames.
Scary, heh?
2011 Ford F-150 Lariat Crew Cab 4x4 EcoBoost
2014 Cruiser RV Fun Finder 215WKS
2015 Harley Road Glide Special in Amber Whiskey
Yamaha Grizzly 660 (his)
Polaris Sportsman 500 H.O.(hers)
rhagfo
Portland, OR
Posted: 01/11/19 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
Snip .......To keep water from dripping down behind the awning (that you're not supposed to leave open when it rains anyway)? T.
Interesting, here in the PNW we always put awnings out in the rain!
2016 Ram 3500 DRW Laramie
2001 Dodge 2500 4X4, 5.9 Cummins, NV4500, 3.55's, Pacbrake PRXB, DS Power Puck,RV 275's Bilstein 5100's, 313K miles.
SidecarFlip
SE Michigan
Posted: 01/11/19 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
Always thought that is what an awning was for myself....[emoticon]
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
pnichols
The Other California
Posted: 01/11/19 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
Hmmm ... for years I've used in my shop one of these, but with only two opposing prongs so that I could hold nuts in place by gripping two sides of the nut. I now carry it in the RV on all trips - just in case: https://www.amazon.com/Flexible-Grabber-Steel-Retriever-Prong/dp/B019N3W81S
Phil, 2005 E450 Itasca 324V Spirit
bukhrn
Lanexa, Va
Posted: 01/11/19 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
X-3, only time I put mine away is before going to bed with a stiff wind.
2007 Forester 2941DS
2014 Ford Focus
