RV.Net Open Roads Forum: Tech Issues: Insulation around fridge
 > Insulation around fridge
Katdaddy
Petal, MS USA
Posted: 01/11/19 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
My fridge died recently. I have a new one coming and I am looking for suggestions for insulation around the fridge for the new installation. As you might expect, the insulation job from the factory was less than optimal. Looking for any ideas from those who have replaced their fridges as to what you used.
As always, thanks for your help.
Little by little, one travels far - J.R.R. Tolkien
There ain't no surer way to find out whether you like people or hate them than to travel with them. - Mark Twain
ScottG
Bothell Wa.
Posted: 01/11/19 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
I've used 1" bat insulation from Home Depot in the past. If you don't have that much room you could use 1/2" rigid foam insulation.
You might also check the installation manual for clearances and how to shape a chimney flue. Doing all of these things makes a huge difference in how the fridge performs, especially in hot weather.
I just spent two days doing all of that on the new TT as I had done to the last one.
A good winter project!
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
SidecarFlip
SE Michigan
Posted: 01/11/19 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
1" unfaced bat insulation here as well. Lay it in and set the fridge and stuff in some more from the backside, across the top and bottom. More the merrier. Wear gloves and a face mask.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
ScottG
Bothell Wa.
Posted: 01/11/19 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
A lot of times there's a large cavity of open space between the top of the firdge and the ceiling. I fill that area with insulation as well.
Katdaddy
Petal, MS USA
Posted: 01/11/19 07:54pm Link  |  Quote  |  Print  |  Notify Moderator
I'm going to have to say the chimney works just fine as is. We have lots of hot days in south Mississippi and never had any problems with the fridge holding temps. And, the insulation was missing in several areas on the original install from the factory. I was just wondering if the bat insulation or foam boards were any better.
ScottG
Bothell Wa.
Posted: 01/11/19 09:05pm Link  |  Quote  |  Print  |  Notify Moderator
While you have the fridge out, look up a tthe vent in the ceiling. If it's just a rectangular hole in an otherwise flat ceiling then your missing out. The effect of fixing it will be greater than insulating because with better flow, it wont have to run as much.
But it's up to you.
Good luck.
Clay Smith
Quartzsite, Az
Posted: 01/11/19 10:39pm Link  |  Quote  |  Print  |  Notify Moderator
While I had my refrigerator out to replace it's cooling unit, I cleaned out the old insulation that was falling from the sides of the cabinet. Then I purchased a water heater fiberglass insulation blanket that measured 48" by 84". I cut the plastic lined insulation right down the middle so I had 2 pieces 24" wide to fit the sides of the cabinet. When I then cut these 2 pieces for the higt of the cabinet, I ended up with 2 pieces that was able to be fitted across the top of the refrigerator. Having the plastic lined insulation made it much easier to slide the refrigerator into place without it catching on the insulation.
Old-Biscuit
Verde Valley
Posted: 01/11/19 11:44pm Link  |  Quote  |  Print  |  Notify Moderator
Dometic RM2652/2852 Installation Manual
Check out 'Clearances' and 'Ventilation' sections
profdant139
Posted: 01/12/19 11:21am Link  |  Quote  |  Print  |  Notify Moderator
You might find these posts useful:
Fridge insulation
If you have a lot of dead space above the fridge, this may be of interest:
Storage in dead space above fridge
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
Katdaddy
Petal, MS USA
Posted: 01/12/19 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
But it's up to you.
Good luck.
It is a rectangular opening above the fridge. How did you modify this for better performance?
