RV.Net Open Roads Forum: Truck Campers: Swing out jack brackets
 > Swing out jack brackets
Troutguy
Midwest USA
Posted: 01/11/19 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
Wharfcat,
What brand of jacks are on your camper.....Happijac or Atwood or Rieco/Titan?
TG
2018 RAM 3500 Crew Cab 4x4 DRW Cummins HO, Aisin trans and 4:10 gears, 14,000 lb GVWR
2018 Arctic Fox 1140 Truck Camper & Honda EU2000
Wharfcat
TEXAS
Posted: 01/11/19 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
Troutguy wrote:
Wharfcat,
TG
They're Atwood. Couldn't even see where Atwood still makes them. I'd like to find or fab the key so that if I had a jack motor fail I could use my cordless drill to operate the jack.
2019 F-350 DRW Crew Cab
2003 Lance lite 1025
2013 Honda CRV
Wharfcat
TEXAS
Posted: 01/11/19 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
They say a picture is worth a thousand words, these are worth several million.
I Think I could figure this out with these pics even if I didn't speak English. You guys are awesome! If you can't tell I buttering you up for more questions to follow. Cheers.
NRALIFR
Truck Camping Out West
Posted: 01/11/19 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately, Atwood sold the division that made truck camper jacks to Lippert (who owns the HappiJac brand) and they have abandoned what was clearly a superior product. Consequently, the supply of replacement parts for our jacks is drying up. There are still a few places that have a limited supply of Atwood parts. Check Panther RV Products, they may still have the drill adapter.
[emoticon][emoticon]
* This post was edited 01/12/19 06:00am by NRALIFR *
2001 Lance 1121 on a 2016 F450
GAR2
Illinois
Posted: 01/11/19 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah I'm retired oil field trash so it doesn't look too tough. I've got a porta-band but I'd prefer to pay a cut charge, then all I have to do is drill some holes and bolt it up. Might change my mind when I see the price on the cut charge. I'm a recovering tightwad.
?? Well, post some pics. when you’re done— would like to see. I’m still working on my truck getting it where I want it. Already swapped out large Mishimoto A/T cooler- 6.0 style, small upgrades on the 7.3L, pulling bed later this month replacing bed support ribs, adding rear air bags, new shocks, new rotors, and more— this site has been helpful while I get ideas in narrowing down my search for a T/C
NRALIFR
Posted: 01/12/19 06:08am Link  |  Quote  |  Print  |  Notify Moderator
Looks like Panther RV is out of stock on the drill adapter.
Look on Amazon, I’m seeing several sellers there that claim to have some available.
Atwood drill adapter 85385
burningman
Seattle, WA USA
Posted: 01/12/19 07:54am Link  |  Quote  |  Print  |  Notify Moderator
That adapter seems like the kind of thing you could make out of a 12-point socket if you can’t buy one.
2017 Northern Lite 10-2 EX CD SE
99 Ram 4x4 Dually Cummins
A whole lot more fuel, a whole lot more boost.
4.10 gears, Gear Vendors overdrive, exhaust brake
Built auto, triple disc, billet shafts.
Kelderman Air Ride, Helwig sway bar.
djg
Caledonia, On
Posted: 01/12/19 07:59am Link  |  Quote  |  Print  |  Notify Moderator
When I got my extenders you could buy the 4" plate as seen in the picture lots of clearance
Dave
2015 Livnlite Camplite TC10
1995 Ford F-350 dually 7.3 Diesel
Wharfcat
TEXAS
Posted: 01/12/19 09:56am Link  |  Quote  |  Print  |  Notify Moderator
I thought of that or maybe a pipe nipple. I don't have access to a milling machine. could cut the slot with the porta-band. Would be a good rainy day project.
deserteagle56
Nevada
Posted: 01/12/19 09:58am Link  |  Quote  |  Print  |  Notify Moderator
Even with swing-out brackets my Bigfoot would not fit on my Ram dually. I had to add a 4" extension, but the way the brackets work on the Bigfoot I had to use 4" channel. Otherwise, the jacks would not lock into the open or closed position.
With that much extension I still have only about 1" clearance on each side for the fenders.
1996 Bigfoot 2500 9.5 on a 2004 Dodge/Cummins dually
