RV.Net Open Roads Forum: Tech Issues: AC/DC Compressor Refrigerators
 > AC/DC Compressor Refrigerators
gemsworld
Arizona West Coast
Posted: 01/11/19 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
I was looking at a motorhome that was equipped with an all-electric compressor refrigerator. I have never seen one before in a motorhome.
I found a video on the net about the pros and cons of compressor v. absorption units and some of the pros on the compressor units is the ability to regulate the temperature much better and the fridge does not need to be leveled. One of the negatives is the sound they make when the compressor comes on, just like the residential units.
It's worth mentioning the RV came equipped with 200 watts of solar panels to help keep the batteries charged. As someone that dry camps frequently, I'm wondering how often the generator has to run to keep the batteries charged. As you all know, absorption refrigerators can run practically forever on very little propane.
I'd like to hear from anyone that has one of these RV compressor refrigerators, not the residential ones.
The link below shows the refrigerator I saw in the motorhome. There is next to nothing on the net about these fridges so I'm assuming they're fairly new.
https://www.rvpartscountry.com/Norcold-AC-DC-RV-Refrigerator-DE006-1r-built-in.html
Crestview area, Inyo County, California
Posted: 01/11/19 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
Adequate solar doesn’t help keep the batteries charged. It fully recharges almost every day. Do an energy use survey. That’s where you start to determine necessary battery AHs, solar panels, controller and wiring.
Info says 3.2 amps when running on 12 volt. https://www.rvupgradestore.com/REFER-DE0061TR-p/72-4825.htm
* This post was edited 01/11/19 09:16pm by Lwiddis *
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
mobeewan
Hampton, Va
Posted: 01/11/19 09:44pm Link  |  Quote  |  Print  |  Notify Moderator
I've been looking at Novakool. They make Marine refridgerators and freezers that can run on 12v or 24v. One similar in size to the Norcold is only a couple hundred dollars or so more expensive, but they are proven units used in boats. I've seen a couple YouTube videos were people built their own campervans from scratch and installed Novakool units. They also had solar panels installed on the roofs with about 400 to 600 watts of battery.
Since I plan on using solar in the future and building a camper van or enclosed 16 foot utility trailer/camper with 800 to 1000 watts of solar I'll probably go one of 2 routes. One is a large Domestic chest refridgerators/freezer in freezer only mode and a dorm fridge. The other route is a tall Novakool with freezer on the bottom and if needed a small dometic chest freezer/fridge I can fire up if I needed a little extra freezer space.
If I stick with just my 28 ft TT I am considering adding solar any way. I might also replace my weak Norcold with a Novakool.
RJsfishin
Winston Or.
Posted: 01/11/19 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
Many yrs ago I had a Norcold AC/DC in a 25 ft Bayliner for 15 yrs, and other than getting a larger alternator on the 350 chev, there was never a problem. But we seldom went out in hot weather, so good reason why battery power was never a problem w/ 2 6v golf car batts.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
theoldwizard1
SE MI
Posted: 01/12/19 05:42am Link  |  Quote  |  Print  |  Notify Moderator
Depending on your needs, I have seen a lot of high end fifth wheels (at shows) with standard household refrigerators. I would NOT limit myself to an AC/DC refrigerator although one that runs off of DC might be a bit more efficient. Don't turn your nose up at 24VDC.
Solar/generator use is hard to say. First of course, is power consumption by the 'fridge and the inverter, if you are using one. If the 'fridge is going to run off of an inverter, make sure it is a pure sine wave inverter. As for a house battery bank, you want a minimum to TWO 6V golf cart batteries. 4 would be better.
Bill.Satellite
Full-timer
Posted: 01/12/19 05:57am Link  |  Quote  |  Print  |  Notify Moderator
A 7 CF fridge? No thank you!
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
jplante4
Cape Cod
Posted: 01/12/19 07:36am Link  |  Quote  |  Print  |  Notify Moderator
We have the new Dometic AC/DC compressor in the store. When we first got it we hooked it up to a group 27 12v battery and it ran for 40 hours before the battery got down to 10.7 volts. Then we plugged it in and watched the temp. It stayed constant until the whole thing stopped working in 2 months time.
I have 200 watts of solar and 4 GC2s and after a few dry camping trips, I'll be adding another 200 watts of solar. We ran the generator every other day, both to charge the bank and run the DW's hair dryer.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
Wherever I happen to park
Posted: 01/12/19 07:45am Link  |  Quote  |  Print  |  Notify Moderator
There are two types of All-Electric Compressor refrigerators
One is the typical RESIDENTIAL type 100-300 watts running. Starting can be over 500 to 1000 watts.
The other is the high effiency or "Danfoss class" (Danfoss is one of the companies that make this type of compressor. there are others as well)
Norcold and Dometic both offered units of this type.. As do other companies in other formats.. For example I have an aux freezer that is 13 years old and of this type (it is a chest freezer about the size of a 35-40 gallon ice chest type cooler but not as big inside) These units typically run on 12 or 120 volt via a power conversion system and inverter on board.. Typically draw 30 to 50 watts running As I said mine is 13 years old. I run it on 12 volts. unless there is a issue on the 12 volt side of life than I run it on 120.
Very happy with it.
Home is where I park it.
3 tons
CA.
Posted: 01/12/19 08:05am Link  |  Quote  |  Print  |  Notify Moderator
For the Novakool RFU 6800 they list the amps at 5.2 @12v, so a sufficient of solar to augment makes perfect sense.
gemsworld
Arizona West Coast
Posted: 01/12/19 08:13am Link  |  Quote  |  Print  |  Notify Moderator
Are you saying the fridge stopped working as in it failed after being used for only two months? If so, what was the cause of the failure?
For those that are wondering if an inverter is needed to run the fridge. From what I understand the fridge runs on 12V DC so an inverter is not needed.
