RV.Net Open Roads Forum: Preparing for Cross Country Trip in 2003 Jayco Greyhawk
 > Preparing for Cross Country Trip in 2003 Jayco Greyhawk
sullivanclan
Grand Junction, Colorado
Posted: 01/11/19 11:32pm Link  |  Quote  |  Print  |  Notify Moderator
The wife and I are preparing for a long road trip South with our older Jayco Trailhawk MH. It has just 52,000 miles on it and we have kept up with maintenance.
My question is, what vehicle parts for the Ford 450 would you all purchase ahead of time to keep in the vehicle for longer trips? Sometimes locating parts on the road during a problem can take a bit of time even though someone might be available to fix it.
We already carry a basic tool kit, emergency road reflectors, colored vest, spare with a bottle jack, air compressor, tow strap, and jumper cables.
Any typical parts for this engine that might be easy to carry and store?
Thanks!
2003 Ford 450 Jayco Greyhawk 25D
1986 Jeep Renegade
2011 Jeep Unlimited Rubicon JK
Old-Biscuit
Verde Valley
Posted: 01/11/19 11:48pm Link  |  Quote  |  Print  |  Notify Moderator
Credit Card and good Cell Phone
Regardless of which spare parts you carry...it will NOT be the one you need IF needed!
How many spare parts do you carry around in your other vehicles?
RVs are no different.
YES things fail but if you have a known issue fix it before you leave.
Otherwise.ENJOY THE TRIP
IB853347201
Eastern Ontario
Posted: 01/12/19 07:18am Link  |  Quote  |  Print  |  Notify Moderator
What Old-Biscuit said plus maybe Roadside Assistance coverage?
Good Sam or FMCA should do it.
bobndot
Posted: 01/12/19 07:23am Link  |  Quote  |  Print  |  Notify Moderator
When I was driving 15 and 16 year old vehicles on trips the list of needed parts
could fill a utility trailer. Having only 52k miles on a 16 yr old vehicle means it sat a lot, had a lot of down time.
DrewE
Vermont
Posted: 01/12/19 07:31am Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't carry anything in particular aside from the basics (which you seem to have pretty well covered). Frankly, I suspect you'll have more trouble with the house systems than with the Ford chassis; it's pretty rugged, and if it does have problems service is not too hard to find, nor are parts rare and unavailable.
A year and a half ago I took a cross-continent trip (Vermont to Alaska and back) in my '98 Ford E-SuperDuty based Coachmen--the E-SuperDuty was renamed to the E450 after a couple years--and the only chassis problems I had were "permanently lubricated" ball joints that ceased to be lubricated due to the rubber booties breaking down and wearing out, and a tire that failed. Carrying a spare set of ball joints doesn't seem at all logical, and I could put my spare on to get to a tire shop and replace all the tires as they were getting pretty well worn by that point at the end of the trip anyhow.
I'd just make sure it's up on regular maintenance and enjoy the trip.
Desert Captain
Tucson
Posted: 01/12/19 08:15am Link  |  Quote  |  Print  |  Notify Moderator
One of the best things about running Ford E-350/450 is that any parts you might ever need can be had just about anywhere. Between the internet, local auto parts stores and overnight shipping, there is virtually nothing you can 't have in 24 hours. Add to this equation the fact that there are Ford dealerships all across the nation and just about any independent mechanic can work on your coach.
As noted a 15 year old coach with 52,000 miles probably suffers more from neglect than use. Make sure all of the requisite maintenance is current - cooling and brake systems flushed, oil, trans, and differential changed {going to pure synthetic is a good idea}. Get your tires inspected and aired to the proper psi for the loads they will actually be carrying {and watch the DOT code dates}.
You might consider adding an inexpensive compressor and/or some sort of jump start/charger {Harbor Freight is a good place to shop}. An assortment of fuses takes little space and can be cheap insurance. A reliable emergency road service is a must as well {I like Coach Net}.
[emoticon]
jamesham
Illinois
Posted: 01/12/19 11:16am Link  |  Quote  |  Print  |  Notify Moderator
A cell phone with CoachNet number on Speed Dial is the best emergency tool. If breakdown beside the highway, getting towed to safe spot is my first concern.
I have a 96 motorhome, so have the age concerns that comes with such a machine. My limited replacement parts box has: fuses, sepentine belt, radiator hoses, light bulbs, and some hunks of fusible wire. Ford 450 parts are easy to get via overnight service so not hard to find after you determine what is needed.
Tool box has Rescue Tape as my primary go-to product for everything from electrical to water leaks. The usual Eterna Bond, Duck Tape, Metal Tape, Super Glue, Silicone Spray and WD40 goes in any RV.
Battery jump pack and Air Compressor take up a lot of space but great when needed. To save space, the Schumacher model SJ1332 does both, and provides an inverter too for low-wattage use.
I do not leave home without a new spare tire and an unmounted old one for emergency backup. Some would not have all of the weight and space of a spare, so it is a personal choice.
camperdave
northern, California
Posted: 01/14/19 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
Back in the day, I used to carry hoses, belts, plugs, fuses, fuel pump and filter, etc. These days you can get anything tomorrow from anywhere, so I carry a credit card. [emoticon]
There's not much that goes wrong with the E450. Fuel pump is probably the most likely thing to have an issue with, but it's not exactly side of the road DIY so no point in carrying a spare...
Best advice would probably be to make sure everything is in tip-top shape when you leave. Flush the brakes, make sure front end is solid, good tires, and change all fluids. Advice I should be taking right now, actually!
2004 Fleetwood Tioga 29v
suprz
rhode island
Posted: 01/16/19 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
X2
Proud father of a US Marine
4x4van
California
Posted: 01/17/19 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
I always carry belts, hoses, and fuel filter (and of course tools). Those items will stop you in your tracks but can be easily replaced alongside of the road. Fuses, electrical tape, wire...
Of course, if you have it, you'll likely never need it!
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R (2), '85 BW200, '07 TRX400EX, '12 Husky TE310
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II, '95 FX1
