RV.Net Open Roads Forum: Tow Vehicles: switch from 265 to 285 tires
Search only in Tow Vehicles
 > switch from 265 to 285 tires
TRIPLE8
Crestline
Posted: 01/12/19 08:36am Link  |  Quote  |  Print  |  Notify Moderator
Hi, I have a 2006 chevy Silverado 2500 4x4 (stock height) that currently has 265/75/16 tires (stock is 245/75/16). I am thinking of going with 285/75/16 tires. I am wondering if they will fit the stock wheel and have enough clearance without a lift. Thank you
06 chevy silverado 2500 d-max
'08 stellar 32' fith wheel triple axle conversion- Lance's pad when Melissa's mad">
2011 Lance 855 non slide
2007 KTM 525 EXC
2015 Polaris RZR 900s
87 Suzuki Samurai (highly modified)
blt2ski
Kirkland, Wa
Posted: 01/12/19 08:42am Link  |  Quote  |  Print  |  Notify Moderator
What width is the rim? Many stock rims are not wide enough for 265's, much less 285's!
With that said, their are some cases where having a slightly narrow rim is better than wider, like off roading, this protects the rim, along with potentially getting a bead removed at lower psi........ Reality, if loading heavy, you need the correct width rim. I noticed lack of handling with the stock 6.5" rim, vs the aftermarket 7.5" rim with 265's, on my 88 and 96 SW 3500's. I can not in all contagiousness recommend 265's, much less 285's on a stock 6.5" rim, if that is what you have.
Marty
Check RV.Net Blogs at: blog.rv.net
TRIPLE8
Crestline
Posted: 01/12/19 08:48am Link  |  Quote  |  Print  |  Notify Moderator
Hi, I do believe the stock wheel to be 6.5
blt2ski
Kirkland, Wa
Posted: 01/12/19 09:44am Link  |  Quote  |  Print  |  Notify Moderator
I won't recommend it because of lack of rim width.
As far as a lift.....you may get away with some trimming of fort bumper,. I had to do this with 265s. 285s trimming and raising torsion bars may work. Rear an add a leaf, least favorite option, a new spring pack that lifts rear an inch or two at also work
IMHO, you.need a 7.5-8" rim for the 265s!
Marty
MitchF150
Puyallup, WA
Posted: 01/12/19 09:58am Link  |  Quote  |  Print  |  Notify Moderator
I had 265 tires on a 7" wheel and that was pretty much all you could do. I know folks put on 285's on the stock wheels, but they pull the sidewalls in a lot and not recommended as Marty said.
My F150 has the 20" wheels that are 8.5" wide and have 275's on them. I could probably go to a 285 or even a 295 at most, but I'm not interested in doing that with this truck.
Without a level or 'lift' you might find 285's might rub on the front when turning lock to lock.. You can usually get away with trimming whatever it's rubbing on if it's plastic. If you start rubbing the fender itself, then you should raise it a bit.
Good luck!
Mitch
2013 F150 XLT 4x4 SuperCab Max Tow Egoboost 3.73 gears #7700 GVWR #1920 payload. 2003 Prowler Lynx 722F #5000 GVWR and weighs every bit of it! "> Happy Camping!
TRIPLE8
Crestline
Posted: 01/12/19 10:11am Link  |  Quote  |  Print  |  Notify Moderator
Thank you for the replies. I have no problem getting wider rims I was most worried about rubbing. Thank you
Posted: 01/12/19 10:12am Link  |  Quote  |  Print  |  Notify Moderator
OE Dodge Ram wheels fit on your Duramax. The 3rd gen 17" X 8" wheels even accept the GM hubcaps.
In my experience, 285-70-17 rubbed slightly at full lock. But measure your truck. Mine sat up a bit higher than some. If yours is a saggy Dmax, then 265s.
This is not a question we can answer. Measure your clearance.
03 Arctic Fox 860
07 Dodge 2500 deezul
Bedlam
PNW
Posted: 01/12/19 10:16am Link  |  Quote  |  Print  |  Notify Moderator
You can get away with more variation between tire and rim width with taller sidewalls, but the tire you wish to purchase will usually have rim width suggestions for its use.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
blt2ski
Kirkland, Wa
Posted: 01/12/19 10:20am Link  |  Quote  |  Print  |  Notify Moderator
I need to point out, which I did not do well earlier. What I mentioned doing, is what I did to my 88 and 96 8 lug GM SW 3500 trucks.
As noted, you will have to try it.out, measure etc.
I do not see anyone discouraging you by any means, just be cautious. An FEA may be needed depending on how tires sit, steering after adding taller and wider tires, longer shocks......
Marty
ScottG
Bothell Wa.
Posted: 01/12/19 10:23am Link  |  Quote  |  Print  |  Notify Moderator
I made that exact change and it screwed up my gearing bad.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
