RV.Net Open Roads Forum: Tow Vehicles: switch from 265 to 285 tires
Search only in Tow Vehicles
 > switch from 265 to 285 tires
blt2ski
Kirkland, Wa
Posted: 01/12/19 10:38am Link  |  Quote  |  Print  |  Notify Moderator
ScottG wrote:
I made that exact change and it screwed up my gearing bad.
I was thinking about this too! If one has 4.10s, you go from a 245 size as noted to a 265, you've effectively lowered the ratio to a 3.95. A 285 to a 3.73. If starting at a 3.73...> 3.55 @ 3.42 effective ratio. A gear change @ 1500 per pumpkin if an 8 lug gets pretty pricy.
My 88 with a th400 3.73 gears was noticeably worst. My 96 6.5rd with 4.10s and 5 sp manual imho made it a bit better...still noticed some initial loss of power on take off. A bit better rpm on freeway.
Marty
Check RV.Net Blogs at: blog.rv.net
ksss
Eastern Idaho
Posted: 01/12/19 11:06am Link  |  Quote  |  Print  |  Notify Moderator
I have done the same thing on my '18 Chevy 3500 SRW. I am pulling the 285's off. Looks cool, great in deep snow, but the mpg penalty is not worth it. I have clearly pulled the L5P out of its optimum ratio.
2006 GMC 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2015 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
TRIPLE8
Crestline
Posted: 01/12/19 11:10am Link  |  Quote  |  Print  |  Notify Moderator
Thank you all, Gear ratio is something I never thought about. I think I will just stick to the 265's ive used for years. Thanks for all the info.
06 chevy silverado 2500 d-max
'08 stellar 32' fith wheel triple axle conversion- Lance's pad when Melissa's mad">
2011 Lance 855 non slide
2007 KTM 525 EXC
2015 Polaris RZR 900s
87 Suzuki Samurai (highly modified)
monkey44
Cape Cod, MA and Central Fla
Posted: 01/12/19 12:25pm Link  |  Quote  |  Print  |  Notify Moderator
I put BFG 285 on my 2015 Chevy 2500HD 4x4 DCab- 4:10RE - Stock Rims - NO problems, no rub, rides and look better in my opinion. The install was done at my local Chevy dealer, so he had no issues with the stock rims and 285's...
I took off General 265's - there was some issue with the stock tires, and dealer was changing under warranty. I paid a little extra and had him install the BFG 285's instead. Great fit, no issues highway or back-roads.
Regards the gearing issue -- I do not notice any difference in the power between 265s and 285s, and we haul our camper in the Rockies as well as flatlands ... I also notice MPG similar hauling the camper, but a slight MPG increase when empty on the highway - not enough to matter or even notice, although I have no real world comparison documented.
Monkey44
Cape Cod Ma & JAX Fla
GMC 2500 4x4 Sierra X-Cab
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
2002 Angler 8B
Back-country camping fanatic
ScottG
Bothell Wa.
Posted: 01/12/19 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
I would not expect you to notice a gearing difference with just a TC on. The difference shows up when you load it down with a heavy trailer.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
BenK
SF BayArea
Posted: 01/12/19 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
Every tire has specifications and one of the columns is recommended rim width.
  • Narrowest will provide the best 'Ride Quality" and the most sidewall bend back
  • Widest will provide the best handling...for that rim width & tire...AKA smallest slip angle, and the lest sidewall bend back
Decide which is more important for youselves. Mine are 10" wide vs the tire recommendation of 8" wide for a LT265/75R16E. Exactly what I want: ride quality is horrible and the slip angle is very smalle
Better to use "Rev's per mile" to review the effect on your engine rev's/speed you wish to be at. Need your ICE's torque/HP curve to do so effectively. Along with all of the gear boxes from the ICE to pavement. Of course need the OEM info as a datum
What hasn't been discussed is the wheel off set. Ditto needing OEM spec in order to figure this out
Then measure both static and dynamic dimensions THROUGHOUT the travel for both sides of steering wheel lock to lock. That will tell if it will rub
Why more and more of the large installer corporations won't mount anything other than OEM for 'that' vehicle. Costco was one of the first to do so. Many independent franchise owners will, but they will have fine print to CYA themselves
This might help, but do so at your own risk (my CYA)...most fender sheetmetal will have a bend back lip on the wheel opening. That is the most likely part to rub, along with the forward and rearward corners. Get a 2" dia water pipe (steel) about 4'-5' long and roll it along that bendback to fold it upwards into the fender...but that will only solve the upper bendback interference
Have always loved over sized tires and have no problems with using a saw-zaw if needed on my trucks. Cars is another topic
-Ben Picture of my rig
monkey44
Posted: 01/12/19 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
Scott - yes I agree with you about TC vs TT ... however, we did notice a difference in the ride with the new tires, significant difference. I've always bought BFG AT tires, years in the building trades and years camping. We always had HD trucks ... only once a 1500, and it would not do either job ... TC only weighs about 3000 lbs, so fairly light compared to some but still needs the 2500HD ...
I do notice quite a difference tho in the 2003 HD - 4 spd w/6.0L at 3:73, versus the 2015 6.0L-6 spd and 4:10, altho some of that is newer engine tech and performance I'm sure.
