RV.Net Open Roads Forum: General RVing Issues: Replacing House Batteries.
 > Replacing House Batteries.
Paul1944
Blanchard, OK
Posted: 01/12/19 10:46am Link  |  Quote  |  Print  |  Notify Moderator
I need to replace my house batteries in my 2004 Coachmen Sportscoach. I currently have four 6 volt deep cycle golf cart batteries installed, two 6 volts hooked in series to create 12 volts then the two 12 volts pairs hooked in parallel. I'm thinking I would like to install the optima maintenance-free batteries but I can't figure out which battery I need to order or how many I need. Any help will be greatly appreciated. Thanks.
Paul & Margie
MrWizard
Traveling
Posted: 01/12/19 10:59am Link  |  Quote  |  Print  |  Notify Moderator
Forget optima, those spiral wound batteries have less capacity
Four of those will give you about half of the capacity in ampHrs that you have now
Get good quality AGM batteries like full river ?
Radiate The Happy
1997 F53 Bounder 36s
2oldman
Salton Sea
Posted: 01/12/19 11:01am Link  |  Quote  |  Print  |  Notify Moderator
Why those?
Paul1944
Blanchard, OK
Posted: 01/12/19 11:04am Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
Why those?
Because they are maintenance-free, am I showing my ignorance here? Maybe there are other maintenance-free batteries that I don't know about.
2oldman
Salton Sea
Posted: 01/12/19 11:05am Link  |  Quote  |  Print  |  Notify Moderator
Yes, Lifeline AGM.
pianotuna
Regina, SK, Canada
Posted: 01/12/19 11:12am Link  |  Quote  |  Print  |  Notify Moderator
Optima would be my last choice for an AGM.
Regards, Don
Sam Spade
North Central Florida
Posted: 01/12/19 12:19pm Link  |  Quote  |  Print  |  Notify Moderator
Yes.
ANY AGM battery is essentially maintenance free (sealed).
A "deep cycle" AGM weighs a TON and costs a lot too.
But that's what I got last year.
When you have an "old" RV, it seems like SOMETHING goes bad every year. I don't want to have to worry about the batteries for a while.
P.S. Are you sure that you really NEED that much capacity ??
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
midnightsadie
ohio
Posted: 01/12/19 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
you should NOT mix batteries old and new ,change them all.
2oldman
Salton Sea
Posted: 01/12/19 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, but that's not what he's doing.
MrWizard
Traveling
Posted: 01/12/19 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
he wants to replace all (4)
he just picked the wrong battery, and is asking advice
the Optima 6 pack spiral wound are very rugged
if you have a JET SKI, or bouncing a desert buggy over rocks
but the constructions means the Optima weighs less, and has less 'LEAD', and less ampHrs useable capacity
for RV dry camping you want Maximum capacity per battery size
there are many other 'sealed' AGM batteries that will better serve your purpose other than Optima
