RV.Net Open Roads Forum: General RVing Issues: Replacing House Batteries.
 > Replacing House Batteries.
Veebyes
Posted: 01/12/19 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
Yes, Lifeline AGM.
Replaced my Lifeline AGM last year after 8 years of trouble free, maintenance free service. When I went to the AGM I did away with the potential connection problems of multiple batteries. Put the biggest single battery in the space available which was a 4D case size. About 215ah. Wish I could get an 8D in there. Too big.
2007 Alpenlite 34RLR
covered wagon
Posted: 01/13/19 09:45am Link  |  Quote  |  Print  |  Notify Moderator
Make sure your charging system is going to properly feed those batteries. Different types require different charge voltage/ amp sequences to make them last.
theoldwizard1
SE MI
Posted: 01/13/19 10:18am Link  |  Quote  |  Print  |  Notify Moderator
Trojan makes an AGM 6V golf cart battery (T105-AGM), if that is your goal (AGM). Not cheap and you would likely have to get the special ordered through a golf cart store.
Sam Spade
North Central Florida
Posted: 01/13/19 11:04am Link  |  Quote  |  Print  |  Notify Moderator
WAY too many people worry about that WAY too much.
AGM batteries last just fine with a "standard" charging system designed for wet cell lead acid ones.
OR.....you can spend $500 or more on a custom converter/charger system that will allow your AGMs to last......maybe one extra year if you are lucky.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
Paul1944
Blanchard, OK
Posted: 01/13/19 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
Veebyes wrote:
2oldman wrote:
Yes, Lifeline AGM.
Again, showing my ignorance, what does AGM stand for?
Paul & Margie
pianotuna
Regina, SK, Canada
Posted: 01/13/19 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
Paul
Absorbed Glass Mat.
Regards, Don
Paul1944
Blanchard, OK
Posted: 01/13/19 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Paul
Absorbed Glass Mat.
Thank you.
MrWizard
Traveling
Posted: 01/13/19 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
Optimas are a form of AGM, but have a particular construction
That makes them light weight and rugged to stand vibration abuse
But also lowers their ampHr capacity
Radiate The Happy
1997 F53 Bounder 36s
Veebyes
Posted: 01/13/19 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
AGM Zero maintenance. Sealed. Can be mounted anywhere, even inside the RV under a bed or wherever there is space. Can be mounted sideways. Can withstand a much deeper discharge, & recover, than a flooded battery. In storage, without parasite loads, discharges at half the rate of a wet cell. Good for many more discharge cycles than a flooded battery. Has a lifespan 2-3 times that of a flooded battery.
No, AGMs are not cheap however when all of the above is factored in they make sense especially if some dry camping is going to be done.
Wherever I happen to park
Posted: 01/13/19 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
OPTIMA is a VERY VERY BAD choice I will explain why
Look at the battery. Notice how much of the thing is AIR. (about 1/3) The result is for the same size battery you have less than 2/3 the capacity (60 percent source OPTIA itself).
OPTIMA's are AGM batteries (I know they yammer about gel but they are AGM)
LIFELINE AGM's are a far better choice... Same capacity as you have now. ANd you use GC-2's hook 'em up just like now..
Oh and Optimas are EXPENSIVE for what you get too.
My recommendation is stay with GC-2 Flooded wet from Costco or Sam's if you have a membership Wal*mart can order 'em if you don't. I use DEAK G-20's (A GC2) Myself.
Home is where I park it.
