RV.Net Open Roads Forum: Class A Motorhomes: Absolutely no power
 > Absolutely no power
rk911
Wheaton IL
Posted: 01/13/19 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
BBB66 wrote:
Gotcha...yes that kill switch is on. Weird that the emergency start from the house batteries does not work either.
i've seen switches where the power is off when ON is pressed and vice-versa. try pressing it and see if the power comes back. if it doesn't press it again and see.
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
GGoodsell
Lincoln, CA
Posted: 01/13/19 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
I have a similar problem on my 2018 Thor Chateau C class. Had TWO batteries go dead on a recent trip through the Northwest. Could not take time to mess with charging so wound up replacing chassis battery twice. Obviously a parasitic drain but can't figure where. Have found that turning off the main house battery disconnect switch (next to the entry step) seems to work. I only turn on that switch when I need 12 volt power or are actually driving the coach. When parked and hooked up to shore power I turn the switch off, everything still works in the coach. Coach going in for warranty work next month, finding this problem is at the top of the list. Did call a Ford rep and he mentioned that a "transfer switch" in the engine compartment might not be working properly, hard to accept on a brand new unit.
gbopp
The Keystone State
Posted: 01/14/19 03:21am Link  |  Quote  |  Print  |  Notify Moderator
BBB66 wrote:
Thanks, they are all tight and clean as a whistle...I guess I will start pulling fuses?
Did you remove the terminals and clean them, not just look to see if they are corrosion free?
If I get a little corrosion on the terminals on our 96 Southwind chassis battery, even if I can't see it, I have the same symptoms as a dead battery.
IB853347201
Eastern Ontario
Posted: 01/14/19 07:00am Link  |  Quote  |  Print  |  Notify Moderator
enblethen wrote:
Most chassis batteries are not charged from the shore power. I am guessing that the parasitic loads have killed you battery. Put a battery charger on it, let it charge overnight and try it again in the morning.
Emergency start may start the rig.
Get a trickle charger for the chassis battery.
X2
Touring in our 2010 Suncruiser, beaches, site seeing, national parks, chillaxing..
ggoguen
Zephyrhills Fl
Posted: 01/14/19 08:40am Link  |  Quote  |  Print  |  Notify Moderator
I had a similar problem with a 2013 Thor Daybreak. Chassis battery not charging on shore power, and house batteries not charging from veh alternator. In my BCC the charge/start relay was wired wrong.
way2roll
Wilmington NC
Posted: 01/14/19 09:34am Link  |  Quote  |  Print  |  Notify Moderator
My first Class A was a 2012 and it had disconnects for the chassis and house batts and shore power and alternator both charged both banks. My second class A from the same manufacturer was a 2013 and it did not have a chassis disconnect nor did shore power charge the chassis batts. So it really depends on the RV how each model is set up. Sounds like either you have a chassis battery disconnect and it's off or Shore power does not charge your chassis batts. Your manufacturer should be able to tell you - call them.
BBB66
Ft Bliss Texas
Posted: 01/14/19 09:56am Link  |  Quote  |  Print  |  Notify Moderator
THOR is not the most customer focused company out there. I have a couple inquiries in with them. no response yet.
Thanks for the tips guys! Will send an update soon!!
way2roll
Wilmington NC
Posted: 01/14/19 11:05am Link  |  Quote  |  Print  |  Notify Moderator
Also, in the "for what it's worth" department, starting a gas engine and bringing up to temp without actually driving it can actually cause more issues than it solves. You'll end up with condensation in parts of the engine and exhaust that you don't want. The engine is better left off until you are going to drive it. That is not true however for the generator. The genset should be exercised monthly under a load for an hour or more. Make sure you disconnect shore power first before doing this. Although most transfer switches can be trusted to convert power from shore to genset without issue, for the 30 seconds it takes to unplug why risk frying your electrical system.
As far as the battery, once you find out why it's not charging or disconnecting, you should get your battery bench tested to see if it's shot. Batteries don't like to be discharged less than 30% and won't really recover fully again.
Once I figured out how the system worked on our second MH, I hooked the chassis battery to a trickle charger once a week overnight to keep it topped off if my trips were less than a few weeks apart. Phantom draws without recharging will kill it.
* This post was edited 01/14/19 11:11am by way2roll *
rk911
Wheaton IL
Posted: 01/14/19 11:37am Link  |  Quote  |  Print  |  Notify Moderator
the Trik-L-Start will keep the chasis battery charged while plugged into shore power or while the genny is running...anytime the charging system for the coach batteries is active. we’ve used one for several years now.
* This post was edited 01/14/19 01:43pm by rk911 *
Brian in Michigan
S.E. Mi.
Posted: 01/14/19 12:18pm Link  |  Quote  |  Print  |  Notify Moderator
Without a voltage check on the batteries you have no idea where to go. There must be a starting point.
1990 GEORGIE BOY 28' 454 4BBL, TURBO 400 TRANS,
CAMPING: WHERE YOU SPEND A SMALL FORTUNE TO LIVE LIKE A HOMELESS PERSON.
