RV.Net Open Roads Forum: Water heater, anode rod, electrolysis, and teflon tape
 > Water heater, anode rod, electrolysis, and teflon tape
fj12ryder
Platte City, MO
Posted: 01/16/19 08:13am Link  |  Quote  |  Print  |  Notify Moderator
BB_TX wrote:
Seems even the "experts" are not in agreement. Some web sites have statements such as
Galvanic corrosion refers to corrosion damage that occurs when two different metals are in electrical contact in an electrolyte, where the more noble metal is protected and the more active metal tends to corrode.
Whereas some others have statements such as
This rapid corrosion occurred because of a chemical process called galvanic corrosion. Galvanic corrosion can only occur when two electrochemically different metals are close to one another and also submerged in an electrolytic liquid
Note the word "close" rather than "contact".
So I guess it all depends on which "expert" you are talking to at the time.
Not really, it all depends on the strength of the electrolytic liquid. As the boat guy said "The conductivity of the water is not adequate." And he is talking about salt water which is a much better electrolyte that the water in a water heater. So if you got a strong enough electrolytic fluid it should work without the two dissimilar metals being in physical contact.
Howard and Peggy
"Don't Panic"
BB_TX
McKinney, Texas
Posted: 01/16/19 09:51am Link  |  Quote  |  Print  |  Notify Moderator
After again posing the question to Suburban I got a response from their senior product engineer as follows;
The two metals only have to be electrically connected, not physically connected to one another. The connection can come thru the electrolyte. I’ve attached some light reading on the subject from Materials Science and Engineering: An Introduction 5th Ed.
So I will leave it at that. Functionally for the RV water heater it is a moot point as I have always used tape on the threads and upon removing the rod there has never been more than strings of tape left after the threads cut, shredded, and compressed the tape into the voids to seal the threads leaving most of the threads exposed to metal to metal contact. And the rods have always corroded as designed and never leaked.
* This post was edited 01/16/19 01:03pm by BB_TX *
fj12ryder
Platte City, MO
Posted: 01/16/19 09:56am Link  |  Quote  |  Print  |  Notify Moderator
Ah, I think I see where the fallacy lies: "The connection can come thru the electrolyte." But it has to be a strong enough electrolyte, plain water in the hot water tank isn't really a strong enough electrolyte to contain enough free ions to work well.
So the Suburban guy is correct in general, but incorrect specifically.
memtb
Wyoming
Posted: 01/16/19 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
I have always used Teflon tape, my anode rod .......continues to “sacrifice” itself!
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
Caesar Ritchie
Posted: 04/15/21 05:43am Link  |  Quote  |  Print  |  Notify Moderator
The metal threads do not need to make contact with each other. Electrolysis is the chemical reaction that takes place inside the tank and has nothing to do with the threads. To protect the metal of the water heater you need to take care while choosing the size of the water heater, there must be contact between the anode and the metal of the water heater.
BCSnob
Middletown, MD
Posted: 04/15/21 06:47am Link  |  Quote  |  Print  |  Notify Moderator
Ions flow in the water between the heater metal and the anode rod; electrons must flow between the heater metal and anode rod via an electrical connection (at the threads) in order to balance the charge being produced during electrolysis.
If you disconnect one side of your battery from the RV (no electrical connection) do you get electrolysis inside your battery (do your lights work)?
Read up on Galvanic cells in:
Encyclopedia of Physical Science and Technology (Third Edition), 2003
* This post was edited 04/15/21 07:40am by BCSnob *
RKW
Four Corners, New Mexico
Posted: 04/15/21 05:27pm Link  |  Quote  |  Print  |  Notify Moderator
The most convenient way found to change/monitor the anode rod was to join the threaded plug for the drain hole and the sacrificial anode in to a combo item. That's why the rod happens to be in close proximity to the threaded drain hole plug. The anode could have been located anywhere in the tank and still have worked well.
There is an electrical aspect to sacrificial anode that has nothing to do with threaded plugs. Because the anode is a different metal than the tank,there is a weak electric current in the water which is part of the process.
Ryan
  • 2015 Ford F250
  • 2015 Rockwood Signature Ultralite 8280 WS
  • Dual Honda EU2000i Generators
    The wages of sin are death; but after they're done taking out taxes, it's just a tired feeling.
  • fpresto
    Maryland
    Posted: 04/15/21 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
    It is often stated on RV forums that you should not use Teflon tape on the anode rod threads as it could interfere with the electrical contact.
    While it may be often stated I have yet to see one that wasn't rapidly corrected. Everyone makes it too complicated. A voltmeter set to ohms will quickly prove that there is still continuity with the use of tape. you are dealing with microvolts so it takes very little contact.
    USN Retired
    2016 Tiffin Allegro 32 SA
    lwbfl
    Florida Panhandle
    Posted: 04/15/21 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
    I use electrolysis to clean cast iron. There is no direct electrical connection between the two pieces (sacrificial metal and piece being cleaned) other than water. To make the process more efficient (which also rapidly increased the declining of the sacrificial metal or anodes)Sodium carbonate, Na2CO3, (also known as washing soda, soda ash and soda crystals) is added to the water. Both pieces are submersed in the solution, small positive charge attached to the anode, negative lead attached to the piece being cleaned. The piece being restored loses all organic materials and rust which gets transferred to the anodes. I suppose the point I'm trying to make with all of this is that no direct electrical connection is required for the chemical process other than the water.
    1976 Myself and Wife
    2009 DD
    3 Doggies
    2016 Chevy Z71
    2021 Coachmen Apex 253RLS
    BCSnob
    Middletown, MD
    Posted: 04/15/21 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
    lwbfl wrote:
    .....small positive charge attached to the anode, negative lead attached to the piece being cleaned.
    Doesn’t this simply provide the current (electrons) needed to balance the ion flow in the solution (in place of directly electrically connecting the two metal pieces) and help drive the desired electrochemical reaction?
