RV.Net Open Roads Forum: Tow Vehicles: "Service trailer brake system" on 2016 GMC
Search only in Tow Vehicles
 > "Service trailer brake system" on 2016 GMC
jabres
Ohio
Posted: 01/15/19 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
Have a 2016 GMC 3500, 6.0 gas job with 57K miles.
Constantly now my computer screen beeps "Service Trailer Brake System", even when no trailer is hooked to truck..
took to my local trailer guy, he checked my plug port where trailer lights plug in, and we checked all fuses. he said neither is the problem.
he says its either the factory built trailer brake controller that was built in dash, or the "Module" that is up under the spare tire. Anyone ever have this issue?
He said it would be a guessing game for him. I hate to take it to the stealership for diagnosis though....
ScottG
Bothell Wa.
Posted: 01/15/19 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
I would take apart the connectors behind the bumper and make sure none have moisture in them. Assuming there isn't a failure with the brake controller, it's seeing a connection to the brake actuating wire at the trailer connector. That could be moisture, rodent damage, etc.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
LIKE2BUILD
Decatur
Posted: 01/15/19 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
Are you not under warranty? If you are I'd take it to the dealer and let them sort out the issue.
2012 Sandpiper 32QBBS--Sold ">
'14 Ram 2500|Crew Cab Long Bed|4X4|Cummins
Curt Q20 with Ram 5th Wheel Prep
2000 Crownline 205BR
1997 Ranger Comanche 461VS
'96 Polaris SLT780 PWC
'94 Polaris SLT750 PWC
3 Wonderful Sons (20, 14, & 12)
1 forgiving wife!!!
ksss
Eastern Idaho
Posted: 01/15/19 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
My 08 was doing that this Winter first time I had seen it before. Moisture or issue at the rear plug is cause.
2006 GMC 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
neil57
southern Ontario
Posted: 01/15/19 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
Friends truck had same issue, was the ground on the module up by spare tire. It’s not expensive to just replace it.
2009 2500HD Sierra CC DA
2014 Crossroads Cruiser 35ss
jabres
Ohio
Posted: 01/15/19 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
Like2build- wish it was, just this year GMC was 3 years 36000 miles, which is kinda a joke.
Fisherman
Angus, Ontario, Canada
Posted: 01/15/19 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe a bit of road salt corrosion happening causing electrical gremlins to surface.
Beaker
Brevard, NC
Posted: 01/15/19 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
Had that problem on my 08. Controller replaced under warranty.
2008 Silverado 2500HD Duramax
2010 Cruiser 26RK
deltabravo
Spokane, WA
Posted: 01/15/19 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
Pressure transducer failed on my 2009 back in about 2011.
2015 Nash 17k (bought pre-owned 5/23/18)
jabres
Ohio
Posted: 01/26/19 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
Not that anyone cares lol, but I figured I would update this post incase someone searches this in the future.
I ended up trying out the cheapest and easiest part to replace, bascially throwing parts at it, and bam it worked. My factory trailer brake controller was the problem. I had one sent via Amazon, $43 later changed it out and works like new. No more stupid computer telling me to service trailer brake system. I love my GMC's, but kinda crazy the factory brake controller went bad on a 3 year old truck with 57k miles. O well, could be worse
