RV.Net Open Roads Forum: Tow Vehicles: newer F250 violent shake
Search only in Tow Vehicles
 > newer F250 violent shake
Posted: 01/21/19 12:31am Link  |  Quote  |  Print  |  Notify Moderator
Wonder what the incremental adjuster assemblies are in that tsb? Caster adjusters? I’m unfamiliar how caster is adjusted on ford axles, but front end alignment at 30k Miles seems a little suspect. Unless the front wheels whacked something really hard or some other unlikely conditions that truck shouldn’t need a front end alignment for a long time.
I’d be interested why it was aligned and that may be a clue as to why it got death wobble.
Good luck with it and if I could suggest, if the dealer under warranty can’t figure it out and you’re not handling it yourself, find a good truck/ 4x4 shop with reccomendations.
Most tire and alignment shops aren’t going to be the place to fix it.
Definitely do more research on it before spending any big bucks.
Bigfoot affair
Sweet Grass
Posted: 01/21/19 11:21am Link  |  Quote  |  Print  |  Notify Moderator
Anything vehicle with a sfa can and will probably experience DEATH WOBBLE.
Love watching these youtube videos, crazy!
Death wobble @ 65k
Even brand new with under 1k miles...
Vvvv1010
San Antonio, Texas
Posted: 01/21/19 10:05pm Link  |  Quote  |  Print  |  Notify Moderator
Add a "dual steering stabilizer bar". Go to a Jeep/ 4x4 shop such as 4Wheel Parts and have one installed. With bar you'll feel tighter steering and more control.
Sounds like the "death wobble" as others have stated. Death wobble usually kicks on at highway speeds going from an uneven asphalt surface to a concrete surface.
2011 Jayco Jay Flight G2 32BHDS
2011 Ford F250 6.7L Turbo Diesel
Two 10'0 Kayaks
Iraqvet05
Greenwood, MO
Posted: 01/22/19 06:40am Link  |  Quote  |  Print  |  Notify Moderator
My local Ford dealer is going to look at the truck on Thursday. There are a small number of people reporting this issue on the Ford Enthusiast Forum. I assume it’s more common if there is now a TSB for it. I filled out a concern form with the HTSA and looked at some aftermarket steering stabilizers. There are not many aftermarket stabilizer kits that fit stock height trucks but I found a kit from Pro Comp that should work. If Ford doesn’t apply the TSB, I’ll spring for $160 for the Pro Comp kit and install it myself.
2017 Ford F-250 6.2 gas
2018 Jayco 28BHBE
US Army veteran
lenr
Indianapolis, IN
Posted: 01/22/19 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
I went to Bilstein shocks and a Rancho stabilizer at about 65,000 miles to (hopefully) prevent death wobble. Hitting one of Indiana's rough bridge transitions at about 90,000 we went into wobble until I could get slowed down to 35 mph. An independent alignment shop found one loose joint on the end of the shaft that runs from the steering gear to the right hub (forget the name). We replaced that and the stabilizer with Ford parts. Mechanic stated that the Ford stabilizer was WAY stiffer than the Rancho that came off. The steering was noticeably stiffer after the work, and we've had no problem since. I was suspicious of the track bar from Ford forum reading but mechanic said it was fine.
Personally, I will stick with Ford parts including the stabilizer. Ford has had this design since 2005, so they have some history. The Ford forums make it sound like it has been reported to safety folks many times with no recalls. Stabilizers can get week with age, and just need to be replaced. They do not compensate for worn, loose, parts.
Iraqvet05
Greenwood, MO
Posted: 01/24/19 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
I took the truck into the dealer today. They replaced the stabilizer and have the rest of the parts for the TSB but their alignment rack is out of commission for some building expansion they are having done. I have to bring the truck back to them to replace some caster sleeves and do an alignment. They also replaced some wiring harness that is part of the block heater recall...I didn't even know they put block heaters in gas trucks.
kw/00
Posted: 01/24/19 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
Yes some gas truck have block heaters for the northern climates. Funny though my 09 GMC HD 6.0 has a block heater.... and I live in Florida ??. It’s usually an option, and I guess the original owner wanted it so hence it’s on the truck. Sometimes as well it’s part of a package.
A truck, a camper, a few toys, but most importantly a wonderful family.
Cummins12V98
on the road
Posted: 01/24/19 05:43pm Link  |  Quote  |  Print  |  Notify Moderator
Iraqvet05 wrote:
No lift and factory 18" tires, running 55 PSI in the front and 65 in the rear. I have 34k miles on it and this is the first time I have experienced this. I bought it used with 29k miles...it was a rental before so I don't know the history of the truck other than it had a tire rotate and alignment right before I bought it. I'll take a look at the front end tomorrow and see if there is anything obvious and do some prying to see if I can find any play in the track bar.
Why so much rear tire pressure if running unloaded?
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Iraqvet05
Greenwood, MO
Posted: 01/24/19 05:51pm Link  |  Quote  |  Print  |  Notify Moderator
65 is too much? I have half a bed of heavy snow in the back for traction...didn't seem like the back was an issue.
It just occurred to me the truck spent half the day inside a heated shop...bet they had some cleaning to do. [emoticon]
FishOnOne
The Great State of Texas
Posted: 01/24/19 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
I run 65psi on all tires year round. I received a letter from Ford for my 05 Super Duty a few years ago about underinflated tires can cause this suspension oscillation.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"Built Ford Proud"
'16 Sprinter 319MKS "Wide Body"
