RV.Net Open Roads Forum: Fifth-Wheels: SRW vs DRW
 > SRW vs DRW
Page of 11
klr650goldwing
minnesota
Posted: 01/21/19 09:05am Link  |  Quote  |  Print  |  Notify Moderator
Is there a general rule regarding how much weight is okay for SRW and how much is too much? We are thinking of a larger 5er and not sure how much larger will require a new truck too.
2011 Crossroads Cruiser, CF325CKP
2004 F350, V10, CC, LB, 4X4, 456
2004 Honda Goldwing GL1800
2004 Kawasaki KLR650
1966 Honda 305 Dream
donn0128
Pronounced Ore-gun
Posted: 01/21/19 09:12am Link  |  Quote  |  Print  |  Notify Moderator
My general rule of thumb was always..... fiver over about 13,500 get a dually. Loaded pin weight should always be your guide. Of course its much more complicated than that. Duallies will be more stable when towing heavy. Duallies will cost you 50% more for tires. No answer is as pat as we would like them. Personally other than a under 30 foot fiver I would almost always opt for a dually for stability alone. But then again I dont take my fiver off road either.
Super_Dave
Harrisville, UT
Since you have a specific year and model of truck it would seem that you could easily determine if it could handle the trailer you are considering. I guess out of curiosity, what is the GVW of the trailer you are looking at?
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
firemedic1992
Edmonton, Alberta, Canada
Posted: 01/21/19 09:18am Link  |  Quote  |  Print  |  Notify Moderator
Use this calculator: Calculator
Rear axle weight rating, and payload capacity are key factors. When you use the calculator the last value (Fifth wheel trailer king pin weight percentage override) will tell you what you really need to know
Ivylog
Blairsville, GA and WPB, FL.
Posted: 01/21/19 09:20am Link  |  Quote  |  Print  |  Notify Moderator
You will hear that a big 5er must have DRW but on occasion I pull a 20K load with my SRW BUT I can adjust the pin weight by where I position the load on the trailer. 5er manufactures save money by putting more pin weight (often 20%) than what’s needed for good handling...10 % is enough. This lets them use smaller tires and axles than what you will find under a TT of similar GVW.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
How I tow.
Towing a Prius without a dolly
How I spend the winter.
BB_TX
McKinney, Texas
Every truck of every brand, SRW or DRW, has a specified payload rating. And the specified payload rating for any truck, SRW or DRW, can vary considerably depending on that particular truck configuration. Example, an F350 SRW payload rating can vary as much as 1,000 lbs depending on cab, bed, engine, tires, etc. So there is no one number for all trucks.
rhagfo
Portland, OR
Posted: 01/21/19 09:46am Link  |  Quote  |  Print  |  Notify Moderator
Not the greatest advice, as at 10% pin an 5er would likely chuck badly! It is also difficult to get the pin that low in a normal 5er, GN flatbed no issue, 5er RV not so much.
We just stepped up to a DRW as a future proofing step.
2016 Ram 3500 DRW Laramie
2001 Dodge 2500 4X4, 5.9 Cummins, NV4500, 3.55's, Pacbrake PRXB, DS Power Puck,RV 275's Bilstein 5100's, 313K miles.
jay5er
Livonia Michigan
Posted: 01/21/19 09:51am Link  |  Quote  |  Print  |  Notify Moderator
Just remember one thing DRW (dual rear wheel) will NOT go through a Car/Truck Wash !!
2oldman
Salton Sea
Posted: 01/21/19 09:59am Link  |  Quote  |  Print  |  Notify Moderator
Advantage/disadvantage dually
dually or no 2011
More dually w/5er 2011
Dually vs single 2014 in fivers
ACZL
UPstate,NY
Posted: 01/21/19 10:12am Link  |  Quote  |  Print  |  Notify Moderator
We bought a SRW F350 CC, sb,4x4,6.7 in Dec '14 and at that time had a '06 Cedar Creek Silverback 33LBTHS. Pin wt, 1800, max GVW 13,800, dry 10,800. No probs whatsoever w/ that rig. May '17, upgraded coach to a '18 Big Country 3560 SS, pin 2900, max GVW 16,000, dry 14,000. With the BC, I was over on truck's GVW and tire capacity. Wasn't too worried about the truck (bad advice I'm sure), and really didn't think much a problem w/ the tires. That was until last year and planned trip to FL during height of summer heat. Now the tire concern started to really bug me. Short story, we traded in the SRW for DRW F350 for a total peace of mind with everything regarding the tires erased now. Would we have been okay w/ a SRW.....perhaps. But just had this nagging gut feeling that wouldn't go away. Was always told "Trust your gut instincts". With the DW driving, I didn't feel 1 bit uncomfy w/ her behind the wheel. Do I miss the SRW....you betcha. Like many, do see plenty of SRW trucks towing at least 15.000 lbs + RV.
If your looking for opinions, mine is: 15,000 lb trailer and under your okay w/ a SRW. Wanna go higher....get a DRW.
2017 F350 DRW XLT, CC, SB, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
Page of 11
 > SRW vs DRW
