RV.Net Open Roads Forum: Tech Issues: Dometic RM2652 not cooling
 > Dometic RM2652 not cooling
Page of 6
Travelin2
SW Florida
Posted: 02/08/19 11:32am Link  |  Quote  |  Print  |  Notify Moderator
Will do JK. I did remove it and blew it out. looking through it looks good. I could see the ruby in there. I did not pay attention to the number.
John & Gloria
South West, Florida
2002 Bigfoot 25B21RB
2012 Avalanche Black Diamond LTZ 4x4
Gjac
Milford, CT
Posted: 02/08/19 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
John you have done a very thorough job investigating, cleaning and documenting the problem. You know your cooling unit is fine because it cools on AC. Your flue is clean with a new baffle and you adjusted the propane pressure. The only thing left is the orifice and the burner tube. John Wilson already spoke about the orifice. The last thing to check is the slots in the burner tube. Is it the original one? I know on mine after about 17 years and multiple cleanings with a wire brush the slots became wide allowing more air to the propane mixture. Does the flame flicker at all? Try covering one of the slots with a screw driver tip does the flame get any brighter?
Travelin2
SW Florida
Posted: 02/08/19 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
Well fellas, I want to thank you all for staying with me and wading through this dilemma with me. When JKWilson said to check the orifice to make sure it was the proper size, I went right out and checked it and it was the proper one he mentioned and that was it, I called it a game and went to town and bought a new one. It's still sitting in my truck and I will unload it in the morning. I think I am close to a solution for melted ice cream and am looking forward to some cold brewskies at camp.
jkwilson
Indiana
Posted: 02/09/19 06:45am Link  |  Quote  |  Print  |  Notify Moderator
Sorry you had to take the kick in the wallet. I’d guess with all you’ve done you’d have shaken out the problem if it was repairable. Only guess left is a cracked weld for the flue pipe which means a new cooling unit anyway.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
Travelin2
SW Florida
Posted: 02/09/19 07:35am Link  |  Quote  |  Print  |  Notify Moderator
John,
I would have replaced just the cooling unit but the inside of the refrigerator was all yellowed. We thought it was due to the previous owner using some type of cleaner that discolored it but one of the professional guys that work on these and help us out here on the forum,Chris Bryant, responded that the yellowed plastic liner is a sign that the ammonia has leaked into that compartment. If only I would have mentioned that earlier, it would have saved me lots of work. Because of the yellowing we decided to buy a complete unit. One really good part of this rigamarole that I went through, I discovered that the gas pressure was only 9.8 inches of water column. I turned it up to 11 inches and now the cook stove lights off much better. The extra pressure is evidently making the gas get to the sparker quicker.
Here is a link to the discussion that led to Chris figuring out the clue to reason for all my headaches...
https://www.rv.net/forum/index.cfm/fusea........d/tid/29836674/srt/pa/pging/1/page/1.cfm
* This post was edited 02/09/19 02:06pm by Travelin2 *
jkwilson
Indiana
Posted: 02/09/19 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Gaining an understanding of all this stuff is invaluable. I hate to spend money when I don’t need to, but it seems like you needed to and made sure of it.
Page of 6
