RV.Net Open Roads Forum: Fifth-Wheels: AC problem
 > AC problem
Just Wandering 1
anywhere USA
Posted: 01/26/19 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Your AC is working as designed. It is designed to run on high fan until within a certain preset temp then reduce to low fan to hold the temp.
sk734
AL
Posted: 02/06/19 07:03am Link  |  Quote  |  Print  |  Notify Moderator
Update
Dometic 3 wire single zone ac. Changed board and updated stat. Runs then stops until reinitialize or turn off and back on? No ice up works great when running. Could use some help. Anyone know the cure? Thanks in advance.
rjsurfer
North Carolina
Posted: 02/09/19 05:27am Link  |  Quote  |  Print  |  Notify Moderator
sk734 wrote:
Update
I have the same problem with my single zone unit. AC will run until temp is reached then shut off but won't come back on. I have to run through all the thermostat settings then it will restart.
I don't think it's a nice up issue either but haven't gone on the roof and checked yet.
Ron W
03 Dodge 2500 SRW,SB,EC
2018 Keystone 25RES
DRZ-400SM
DL-650
Learjet
Louisiana
Posted: 02/09/19 10:44am Link  |  Quote  |  Print  |  Notify Moderator
sk734 wrote:
Update
My bed room does that if I leave it on LO fan overnight....I just leave it on HI fan and its happy.
2017 Ram Big Horn, DRW Long Box, 4x4, Cummins, Aisin, 3.73
2015 Wildcat 317RL, MoRryde rubber pin box, Titan Disc Brakes, Trojan T105
B&W Ram Companion
Yamaha EF2600c tri-fuel generator
Champion Model 46595- 3000/3500w
Learjet
Louisiana
Posted: 02/09/19 10:47am Link  |  Quote  |  Print  |  Notify Moderator
from the manual for my thermostat:
"Special Features
Auto Fan
When auto fan is selected the fan speed will vary depending on the
difference between the temperature set-point and the room temperature.
In auto fan the compressor and fan cycle On and Off with the
thermostat.
When the difference is:
>5º The fan operates on HIGH
<4º The fan operates on LOW"
The fan will stop and restart when it changes speed and the compressor will continue to run. Thought it was broken like most when I first got my current rig.
 > AC problem
