RV.Net Open Roads Forum: Beginning RVing: UVW and GVWR and Tow Vehicles
 > UVW and GVWR and Tow Vehicles
saffikeagan
Montrose, CO
Posted: 01/24/19 09:56pm Link  |  Quote  |  Print  |  Notify Moderator
Senario:
5,500lb UVW Toy Hauler.
1,000lb cargo/water/etc max ever pulled usually averaging more in the 500lb range (self-propelled toy-type hauler only)
10,500lb GVWR on the TH
Would I be fine with a vehicle that has a max tow of 8000? (assuming that the 1,000lbs is NEVER exceeded).
twodownzero
NM
Posted: 01/24/19 10:25pm Link  |  Quote  |  Print  |  Notify Moderator
What's the GCWR and GVW of the tow vehicle? "Max tow" is a theoretical number. GCWR - actual GVW = actual tow capacity (assuming other limits aren't busted first).
MitchF150
Puyallup, WA
Posted: 01/24/19 10:54pm Link  |  Quote  |  Print  |  Notify Moderator
All you are going to get with this kind of question is you'll be fine or you'll be overweight and don't do it answers..
But where does that get you?
It's your rig, your tow vehicle, your towing experience, your towing expectations..
If I have never towed before, I would not do it..
If you have towed before and know what you are doing, and actually don't load anything... Ha, ha, only loading #1000 with a toy hauler with a #10.5K GVWR.. Yeah, right.. Anyway, in the end, it's your choice.. Not ours..[emoticon]
Good luck!
Mitch
* This post was edited 01/24/19 11:50pm by MitchF150 *
2013 F150 XLT 4x4 SuperCab Max Tow Egoboost 3.73 gears #7700 GVWR #1920 payload. 2003 Prowler Lynx 722F #5000 GVWR and weighs every bit of it! "> Happy Camping!
bikendan
Camano Island, Wash.
Posted: 01/25/19 02:14am Link  |  Quote  |  Print  |  Notify Moderator
saffikeagan wrote:
Senario:
you left out payload capacity of the tow vehicle and tongue weight of the trailer.
Dan- Firefighter">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 Ecoboost, 2016 PrimeTime TracerAIR 255 w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
edbehnke
North America (from Michigan)
Posted: 01/25/19 06:15am Link  |  Quote  |  Print  |  Notify Moderator
just give us the facts. what kind of trailer and vehicle are you talking about?
eddie and sandie
3402 Montana 2013
Ford F350 2015
ppine
Northern Nevada
Posted: 01/25/19 06:55am Link  |  Quote  |  Print  |  Notify Moderator
I will never understand the concept of having "just enough" tow vehicle.
ken56
Tennessee
Posted: 01/25/19 08:06am Link  |  Quote  |  Print  |  Notify Moderator
At least he is asking. No need to border on being rude in answering. What I am not sure of is:
UVW of 5,500 for the toy hauler
GVWR of 10,500 for the toy hauler. Thats a 5,000 lb cargo weight capacity. I can't say I have ever seen this on a trailer, but I don't have a toy hauler.
Toy haulers usually have a very heavy tongue weight so as when loaded in the rear with the toys it counter balances that. Still need the 10-15 % on the tongue so a trip to the scales when laoded is the only way to find that out.
I really don't understand the numbers he posted.
MFL
Midwest
Posted: 01/25/19 08:37am Link  |  Quote  |  Print  |  Notify Moderator
Great point/answer from MitchF150, totally agree with him! However, if looking for OPINIONS, as to will it work, you need more disclosure, exact tow vehicle and trailer. Most any half ton truck, or SUV can pull 8K, but some will not carry the load safely.
Jerry
SoundGuy
S Ontario
Posted: 01/25/19 08:56am Link  |  Quote  |  Print  |  Notify Moderator
This is the key issue - you need to establish the vehicle's real world payload capacity and whether whatever is remaining after accounting for the weight of everyone and everything in truck to account for the amount of trailer tongue weight you expect the truck to also handle, anticipating that that tongue weight will be in the 13% to 15% range of gross trailer weight once it's loaded and ready to camp. Ignore this most important issue and you could well be towing well beyond the capability of your truck, regardless of what it's so-called "tow rating" may be.
2012 Silverado 1500 Crew Cab
2014 Coachmen Freedom Express 192RBS
2003 Fleetwood Yuma * 2008 K-Z Spree 240BH-LX
2007 TrailCruiser C21RBH * 2000 Fleetwood Santa Fe
1998 Jayco 10UD * 1969 Coleman CT380
drsteve
Michigan
Posted: 01/25/19 11:10am Link  |  Quote  |  Print  |  Notify Moderator
A TH with 10,500 GVWR, loaded to only 6500 lb, is going to have a really heavy tongue, because THs are designed to be able to haul large loads behind the axles, which lighten the tongue.
1991 Palomino Filly PUP
