RV.Net Open Roads Forum: Beginning RVing: UVW and GVWR and Tow Vehicles
 > UVW and GVWR and Tow Vehicles
SoundGuy
S Ontario
Posted: 01/25/19 02:41pm Link  |  Quote  |  Print  |  Notify Moderator
drsteve wrote:
A TH with 10,500 GVWR, loaded to only 6500 lb, is going to have a really heavy tongue, because THs are designed to be able to haul large loads behind the axles, which lighten the tongue.
Regardless of whatever trailer this may be the key is to establish it's average gross tongue weight as loaded & ready to camp, then determine from that whether the tow vehicle in question has sufficient payload capacity to handle whatever that average gross tongue weight may be while also accounting for the weight of everyone & everything also loaded into the vehicle. Until the OP addresses this issue he'll never know the answer to his question nor can anyone here answer his question one way or the other.
2012 Silverado 1500 Crew Cab
2014 Coachmen Freedom Express 192RBS
2003 Fleetwood Yuma * 2008 K-Z Spree 240BH-LX
2007 TrailCruiser C21RBH * 2000 Fleetwood Santa Fe
1998 Jayco 10UD * 1969 Coleman CT380
saffikeagan
Montrose, CO
Posted: 01/25/19 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks to everyone...the snark was ignored. I'm kinda understanding now the importance of those other numbers I haven't figured out yet.
Let's go with these numbers on a Jayco I found a good price on:
Weights & Measures
WEIGHTS
Unloaded Vehicle Weight (lbs) View Definition 4700
Dry Hitch Weight (lbs) View Definition 710
Gross Vehicle Weight Rating (lbs) View Definition 7500
Cargo Carrying Capacity (lbs) View Definition 2800
And a F150 2.7L 4x4 Lariat
Curb Weight
4,806 lbs
6,500 lbs
Max Payload
1,694 lbs
2,250 lbs. – Max. payload capacity
8,500 lbs. – Max. towing capability
Anticipated cargo: enough **** to keep one person alive for a week or so, enough **** to keep two dogs alive for a week or so, two dog beds, a decent mattress, one bowl, one plate, one cup (you get the picture), a 9lb road bike, a 15lb mountain bike and a fishing pole with a cheap plastic wally world special tackle box full of spare ****. I'm definitely worried about maxing out the THs GVWR. *snark back*
Based on what I've figured out so far, I'd be good to go, yea?
The other scenario:
Same cargo, same truck, 21ft Desert Fox
Dry Weight (lbs/kg) 6688
Payload Capacity (lbs/kgs) 3712
GVWR (lbs/kgs) 10400
Hitch Weight (lbs/kgs) 1060
Too much, yea?
* This post was last edited 01/25/19 08:14pm by saffikeagan *   View edit history
saffikeagan
Montrose, CO
Posted: 01/25/19 08:20pm Link  |  Quote  |  Print  |  Notify Moderator
FFS I can't believe they censor the word "cr@p." My guess is the site is too buggering 'murican so just replace all the censored words with "bollocks" and she'll be right.
bikendan
Camano Island, Wash.
Posted: 01/26/19 01:18am Link  |  Quote  |  Print  |  Notify Moderator
Weights & Measures
WEIGHTS
Curb Weight
4,806 lbs
6,500 lbs
Max Payload
1,694 lbs
The other scenario:
Too much, yea?
the Jayco's dry trailer and tongue weights are for a stripped-down version of the trailer. Unless you got the UVW off the trailer's yellow factory weight sticker.
why did you list two different payload capacities for the Ford? the correct number is on the truck's drivers door Tires and Loading sticker. it'll say "Occupants and cargo should not exceed xxxxlbs."
a 2.7 F150 isn't going to have a 2250lbs payload capacity. that high of a payload would be a HDPP F150 with the 3.5 Ecoboost.
Dan- Firefighter">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 Ecoboost, 2016 PrimeTime TracerAIR 255 w/Equalizer and Prodigy, and 5 Mtn. bikes and 2 Road bikes
bid_time
Michigan
Posted: 01/26/19 06:19am Link  |  Quote  |  Print  |  Notify Moderator
Just go to this Site and you can good reliable information with no snark.
mlh
Walker, Louisiana
Posted: 01/28/19 09:58am Link  |  Quote  |  Print  |  Notify Moderator
You need to actually weigh your truck at the scale. You will probably find that your ACTUAL weight is a lot more than the curb weight listed on the web. You will have a lot less payload capacity than you think. There is a good chance that you won't have enough payload to cover the tongue weight, not to mention all the stuff you are carrying.
2018 Ram 2500 crew, 4x4, 6.4L, 3.73
2019 Puma 29QBSS
Equalizer weight distribution and sway control
Posted: 01/28/19 11:31am Link  |  Quote  |  Print  |  Notify Moderator
Realize the biggest hurdle will likely be the heavy unloaded tongue weight. These trailers are designed for hauling heavy toys thus designed nose heavy so the “toys” balance it out.
That said, I would have zero concern about putting up to 1500lbs tongue weight on the back of a new 1/2 ton with some wd bars transferring some of the load up front.
I’ll stay out of the weight cops peeing match though!
The variable is not whether the truck will handle it (it will, easily if properly equipped). The variable is, are you ok towing about anything anywhere (mountains where you live) and have sufficient experience to recognize everything included with towing at the upper end of what the truck will handle? Or are you new to the towing game and prefer some extra factor of safety in the tow rig?
Another option, although I like the TH open concept, is you have 2 bicycles. Get a TT, hang the bikes off the back or put them in the truck bed and have zero tongue weight concern.
03 Arctic Fox 860
07 Dodge 2500 deezul
"Obviously I don't want to overload my truck and be unsafe, but the reality is the truck is way more capable than the 10K GVWR they put on the sticker.
KJ"
kellertx5er
Keller TX
Posted: 02/13/19 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
ppine wrote:
I will never understand the concept of having "just enough" tow vehicle.
How about this - "I ALREADY have a truck. What can I pull with it?"
Not too hard to understand.
Keller TX
'08 F250 6.4L PS
'09 Outback Sydney 321FRL 5er
SUPPORT TEXAS STATE PARKS
drsteve
Michigan
Posted: 02/13/19 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Even if you start with the truck, nothing says you have to buy a trailer that it will barely tow, which is what a lot of folks want to do. And they end up with "just enough truck". Which is a bad idea no matter what order you buy them in.
1991 Palomino Filly PUP
Atlee
Mechanicsville, VA
Posted: 02/16/19 03:49am Link  |  Quote  |  Print  |  Notify Moderator
Wish this forum had a thumbs up function. You hit the nail on the head. I've never liked the idea of towing up to he max limits of my truck.
Erroll, Mary, Duffy the Dachshund (RIP)
www.thetravelingkoala.blogspot.com
2017 Jayco Jay Flight 23RB
2014 F150 Supercab 4x4 w/ 8' box, Ecoboost & HD Pkg
And Blue Ox WDH/Sway Control
