RV.Net Open Roads Forum: Tow Vehicles: Ram 2500 weak heater?
Search only in Tow Vehicles
 > Ram 2500 weak heater?
GordonThree
Northern Michigan
Posted: 01/27/19 08:47am Link  |  Quote  |  Print  |  Notify Moderator
DownTheAvenue wrote:
I doubt you have any mechanical issue with the engine or cooling system. You probably have a blend door that is not completely closing, so the hot air from the heater is blended with cold outside air.
That sounds most plausible.
From everyone's feedback, it seems like something's not right. Will take it to get checked out.
I appreciate the help everyone, thank you.
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
mtofell1
Oregon
Posted: 01/27/19 10:38am Link  |  Quote  |  Print  |  Notify Moderator
Yep, that's not right. My 2014 starts cranking out strong heat within a few minutes. fwiw, I once got a CEL when my thermostat was opening too soon so I agree that's likely not the problem.
Trackrig
Spent the summer in Conconuly, Wa, MH now in Vanco
Posted: 01/27/19 11:20am Link  |  Quote  |  Print  |  Notify Moderator
As stated above, before taking it anywhere to be checked, check the antifreeze level yourself.
I had an old Chevy snow plow truck that had a leaking radiator in it that I attribute to never having flushed the cooling system or changed the antifreeze in, that wouldn't put out sufficient heat when the radiator had lost enough coolant. Fill up the radiator, and it had great heat.
So check your coolant tank. It will have low and high marks on it. Even if it's not below the low or fill mark, fill it up to the full mark and see if it makes a difference.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
Posted: 01/27/19 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
Except on a new(er) truck, you'd get a low coolant message long before it got low enough to not fill the heater core. Likely not the issue here.
FishOnOne
The Great State of Texas
Posted: 01/27/19 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
goducks10 wrote:
2018 Ram 2500 6.4 works great.
We wouldn't expect anything less... would we?
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"Built Ford Proud"
'16 Sprinter 319MKS "Wide Body"
MudChucker
Niverville Manitoba
Posted: 01/27/19 01:05pm Link  |  Quote  |  Print  |  Notify Moderator
Agreed... Sounds like a blend flap issue...
2017 Cougar
2015 Ram 3500 Megacab 6.7 Cummins Aisin transmission
goducks10
There
Posted: 01/27/19 01:49pm Link  |  Quote  |  Print  |  Notify Moderator
Gotta say my Ram 2500 heater is a Jewel.[emoticon]
Sport45
Not far enough from Houston, TX
Posted: 01/28/19 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
GordonThree wrote:
Now that winter's properly arrived I'm noticing that the heat in my 2017 2500 isn't that powerful. It takes a good 20 minutes to heat up the cabin into the 70s. It can't compete with any windows being open even partially.
Anyone else noticed the same? I have the super basic work truck heat, single zone with three speed fan.
Did it used to keep the cab warm with the windows partially open? Does it work okay with them closed?
’19 F350 SRW CCLB PSD Fx4
'00 F250, CC SWB 4x2, V-10 3.73LS. (sold)
'83 F100 SWB 4x2, 302 AOD 3.55. (parked)
'05 GMC Envoy 4x2 4.2 3.73L.
'12 Edge 2.0 Ecoboost
'15 Cherokee Trailhawk
Range Maggot Bob
Missouri
Posted: 01/28/19 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
I can start my truck, turn on the exhaust brake, and my truck is toasty in 5 minutes. But that is diesel; I would think your truck should heat right up itself in about 5 minutes. But with that being said, when in the heat position- pointing right at you- I don't get that much of an air flow. In other words, my heater doesn't blow very hard. I'm wondering if it's because the vents in the backseat of the cab are on, and it's such a large cab. Do you have that problem? Somethin' ain't right if you're not heating up.
Blazing Zippers
North Idaho
Posted: 01/28/19 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
Our 2016 Hemi 6.4 works fine. Last February when coming across the U.S. we encountered cold temps while driving and the gauges showed the thermostat would cycle between 185 and 206 quickly. Once the temps warmed up, the swings in engine temps stopped.
Take it in---there are several recalls popping up that might be on your truck too.
