RV.Net Open Roads Forum: Tow Vehicles: Ram 2500 weak heater?
Search only in Tow Vehicles
 > Ram 2500 weak heater?
romore
Okanagan valley British Columbia
Posted: 01/26/19 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
If your temp gauge reaches 195-200 the thermostat is doing it's job. If your coolant level is at the correct level you may have a problem with a partially plugged heater core, replacing it is not a job for a DIY mechanic.
ScottG
Bothell Wa.
Posted: 01/26/19 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
2017 truck - hope it's hater isn't clogged!
The heater baffles me. Our car (similar eng) has been sitting about 3.5 hours in the 40's today. I got in, started it and after about 15 seconds I checked for heat. Yep, it's blowing slightly warm air.
How the heck does it warm up so fast?
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
MudChucker
Niverville Manitoba
Posted: 01/26/19 08:24pm Link  |  Quote  |  Print  |  Notify Moderator
Is your engine temp gauge indicating where you expect it to be?
2017 Cougar
2015 Ram 3500 Megacab 6.7 Cummins Aisin transmission
GordonThree
Northern Michigan
Posted: 01/26/19 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
Temp "gauge" is in the middle of the dial ... Will try to remember to check the digital readout in the menus next time I'm behind the wheel. no CEL or messages waiting from the computer
2013 KZ Sportsmen Classic 200, 20 ft TT
2017 Ram 2500 4x4, 6.4 HEMI, 4.10 / Auto
ScottG
Bothell Wa.
Posted: 01/26/19 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
For body type codes, your display wont show them.
I had a blend door motor failure and nothing showed for me but the dealer was able to see exacty what motor was bad by the code.
deltabravo
Spokane, WA
Posted: 01/26/19 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
BobsYourUncle wrote:
Maybe you've got a bum thermostat. If it's stuck open it could cause this.
Possibly low coolant too.
Low coolant almost always results in low heat output to the cabin... at least in my older Chevy trucks that was the culprit
2015 Nash 17k (bought pre-owned 5/23/18)
Posted: 01/27/19 02:41am Link  |  Quote  |  Print  |  Notify Moderator
mike-uswest wrote:
I have a 2003 dodge diesel that it takes 5-6 miles before it starts to warm up, but it is fine after that.
Mike
Please
All
Of
You
READ!
OP has a gas motor. Regardless of what the issue is, I guaranty it has little to do with the operation of the heater in a 16 year old diesel pickup.
Posted: 01/27/19 02:45am Link  |  Quote  |  Print  |  Notify Moderator
So bee more specific. Check the actual coolant temp and describe the conditions in which it takes a while to get warm....I.E., it's been -20deg up there.
Truck outside?
Plugged in block heater?
Was it fine last month when not so cold?
Once you can check all those boxes, start looking for a problem if everything else is as it should be.
dodge guy
Bartlett IL
Posted: 01/27/19 06:35am Link  |  Quote  |  Print  |  Notify Moderator
He's talking about the digital temp reading.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
DownTheAvenue
Sunny South
Posted: 01/27/19 07:55am Link  |  Quote  |  Print  |  Notify Moderator
I doubt you have any mechanical issue with the engine or cooling system. You probably have a blend door that is not completely closing, so the hot air from the heater is blended with cold outside air.
