RV.Net Open Roads Forum: General RVing Issues: Looking for a generator
 > Looking for a generator
burgess001
Springfield, MO USA
Posted: 01/26/19 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
Have always had onboard generators with motorhomes. Have downsized to a Travel Trailer. Feeling the need for a generator for the RV, and as a backup for the house. One big enough for the RV Air Conditioner/Microwave, etc would work for the "emergency leg" of the breaker box in the house. What would you suggest? Propane? Duel Fuel? Electric Start? Other considerations?
Jerry and Katie
More than 20 great years motorhoming and still loving it...
2004 DSDP 3810 (more than I needed...less than I wanted)
2004 Trailblazer (too heavy but well worth dragging)
enblethen
Moses Lake, WA
Posted: 01/26/19 09:08pm Link  |  Quote  |  Print  |  Notify Moderator
I would get this one from Harbor Freight.
3500 Watt gasoline genset
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Home Skillet
Pearland Texas
Posted: 01/26/19 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
+1
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
theoldwizard1
SE MI
Posted: 01/26/19 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
That is a good size for a generator and you would likely have no issues running any of the things you mentioned.
A 2000W generator like this Harbor Freight model or this Champion model would certainly run your microwave. You may have to add a "hard start kit" for your air conditioner.
badsix
north bend or.
Posted: 01/26/19 10:27pm Link  |  Quote  |  Print  |  Notify Moderator
Champion 3500 about a 100.00 more and remote start. I just cant make myself depend on anything from Horrible Freight.
Jay D.
romore
Okanagan valley British Columbia
Posted: 01/26/19 11:05pm Link  |  Quote  |  Print  |  Notify Moderator
A 3500 will work for the rv but probably not enough to run the house. Don't forget about the hot water heater, fridge, freezer all of which draw more than the ones in an rv.
What do you mean by the 'emergency leg' in the breaker box? You would need to have a transfer switch wired in by a licenced electrician.
valhalla360
No paticular place.
Posted: 01/26/19 11:43pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 2400w that will run the RV air/con (no hard start or other special features) but it's marginal.
I would lean toward an inverter style of at least 3000w, so you aren't having to mess around to get the air/con to run.
Yes, you can run the house but may need to limit the loads (it won't run the whole house air/con).
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
dmck413
Fluvanna Va
Posted: 01/27/19 04:51am Link  |  Quote  |  Print  |  Notify Moderator
If you have a well a 240 volt generator will be required.
Dave H M
IL
Posted: 01/27/19 07:00am Link  |  Quote  |  Print  |  Notify Moderator
I am interested in what an emergency leg is also.
DownTheAvenue
Sunny South
Posted: 01/27/19 07:50am Link  |  Quote  |  Print  |  Notify Moderator
Jay D.
This is good advice. Service and parts are avialable with a Champion product. You will have great difficulty finding any service center touch a Harbor Freight product.
