RV.Net Open Roads Forum: Fifth-Wheels: 5th wheels rails
 > 5th wheels rails
Ex-Halfton Guy
Los Alamos Ca
Posted: 01/29/19 11:45am Link  |  Quote  |  Print  |  Notify Moderator
Hello
Currently have a cheap pro series 5th wheel
hitch.looking at a B and W patriot 5 wheel hitch.
Can I use my current rails or do I need to get new ones? Thanks
The Wife, my 3 boys Joseph(18)Ryder(4)Kade(2)
2016 Rockwood Signature UltraLight 2801WS
Pulled by a 2012 Ford 350 Desiel 4x4
lee worsdell
elmvale
Posted: 01/29/19 11:57am Link  |  Quote  |  Print  |  Notify Moderator
Should be able to use them. I went to a reese 20 k with my new truck and had to have new rails . I then didn't like it and went back to 16k b w hitch. Really tight fit
Ex-Halfton Guy
Los Alamos Ca
Posted: 01/29/19 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
My old hitch is 16k the one I’m looking at is also 16k
gdweb
Posted: 01/29/19 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
i had the reese 16k, switched to the b&w patriot. same rails, no problem. might be a little tighter but nothing to keep it from going in
Semper Fi
Gary & Diane
Ringor, Blueheeler/Bordercollie mix
2013 F250 6.7l FX4
2013 Sundance 3270res
Ex-Halfton Guy
Los Alamos Ca
Posted: 01/29/19 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
How do you like the patriot hitch?
gdweb
Posted: 01/29/19 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
I like it. seems like it has a tighter fit around the pin. and it doesn't have all the popping sounds of the old reese either. mine is the patriot slider, it slides alot smoother too.
MFL
Midwest
Posted: 01/29/19 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
You will be happy with the Patriot, it is a solid hitch, that is very user friendly. Also once verified, jaws around the pin, handle closed/locked with retaining pin, you are hitched, no way to let go.
Yes, should fit most Reese rails.
Jerry
filrupmark
Richmond,Texas
Posted: 01/29/19 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
I also have a Patriot sitting on Drawtite/Reese rails. Love my Patriot .
2004 Ford F250 Super Duty 6.0 Diesel, Bilstein 4600 Shocks, 16K B&W Patriot, Michelin M&S
2014 Augusta Flex AF34RS Trailair Tri Glide pinbox,
JT Strong Arms , Bridgestone R250'S, KYB Monotube Gas shocks
Finally a smooth ride !!!
Cummins12V98
on the road
Posted: 01/29/19 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
Anything B&W is Top Cabin! Yes there is still quality in the RV industry.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
RobWNY
Jamestown, NY
Posted: 01/29/19 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with the others. My Patriot 16K (bought on the recommendation from MFL-Jerry) last Spring is a purchase I'm very happy I made. Easy, reliable, no issues whatsoever.
 > 5th wheels rails
