RV.Net Open Roads Forum: Travel Trailers: Okay, I have frozen pipes??
 > Okay, I have frozen pipes??
DBHMEH
Missouri.
Posted: 01/30/19 04:51pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2019 TT. Here in Missouri we've had -7 degree temps. I have taken all needed precautions to prevent freezing as I'm a full-timer. I have all accessible cabinet doors open and the furnace is cranked. I know it's frozen on the inside run. Any suggestions that I haven't covered? Also, is the newer plastic water piping less apt to crack? Thanks for any input, David
David & Maureen and Family
2015 Sprinter 319
2006 Dodge Ram 2500 CTD
2004 Crownline 202 BR (Blue Printed 350)
enblethen
Moses Lake, WA
Posted: 01/30/19 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
PEX is less apt to be damaged.
Is there a furnace vent in the wet compartment? Make sure it is on.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
puddleduck
Colorado, USA
Posted: 01/30/19 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
If your water is all frozen, I mean both hot and cold to all faucets and if you have a compartment that houses all of your connections I would guess that your frozen spot would be right behind that door. If you think about it your plumbing is only 1/2 inch of styrofoam away from -7 degrees.
I know these RV folks say they build a four season unit but most of them recommend you not use it in below freezing conditions.
That being said , if you can determine where it is frozen you can take steps to prevent future problems.
Good Luck
midnightsadie
ohio
Posted: 01/30/19 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
you gotta get some hot air moving.
Dick_B
Palos Heights, IL USA
Posted: 01/30/19 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
or wait another day or so. A heat wave is coming!
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
joelc
Cedar Point, NC
Posted: 01/31/19 07:23am Link  |  Quote  |  Print  |  Notify Moderator
If your water is frozen then you might have some cracked pipes too. I had an old camper and the pipes froze one Winter. When they thawed I had water pouring all over. Be careful. It was a MH with a basement, 1988. I had a bulb in the basement to keep it warm and it worked to keep things from freezing until one night when the bulb went out. On the newer RVs they have the Furnace ducting from propane to keep the basement warm and pipes from freezing. I also keep cabinets open. On the outside, use heat tape and foam insulation. So far my 2012 5er has had no issues.
pianotuna
Regina, SK, Canada
Posted: 01/31/19 10:33am Link  |  Quote  |  Print  |  Notify Moderator
Replace the return air grill on the furnace with twin window fans. That keeps some warm cabin air circulating at all times.
As for unthawing, a radiant heater may be the best--the type with tubes which glow cherry red, with a reflector. They heat the object they are pointed at, rather than heating the air.
Regards, Don
bguy
The Rock
Posted: 01/31/19 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
Use a fan.
2010 Ram 1500 Quad Cab, 4x4, 3.55, HEMI
2009 TL-32BHS Trail-Lite by R-Vision
Bob/Olallawa
Kitsap Co, WA
Posted: 01/31/19 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
Yes the pex pipe is not as apt to be damaged but any of the fittings exposed to the cold could be cracked. Shut the water off for now, and when the temps come back up plan on fixing some cracked parts.
Welcome to my home, that door you just broke down was there for your protection not mine.
time2roll
Posted: 01/31/19 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
I recommend adding tank heaters and a circulating pump if you could be caught in a similar situation in the future. Probably a pipe is in an inaccessible area. To really thaw out you need to get into a heated shop overnight. Most of these trailers are just not built to go much below 20F and even fewer (none?)to keep going below zero.
Keep the pump off and disconnected from water while it thaws out. You don't want to have any extra water damage if a break unfreezes.
675w Solar pictures back up
