RV.Net Open Roads Forum: Travel Trailers: Okay, I have frozen pipes??
 > Okay, I have frozen pipes??
OleManOleCan
Alabama
Posted: 02/07/19 10:56pm Link  |  Quote  |  Print  |  Notify Moderator
A small electric heater in a camper at home will keep everything from freezing.
Open any cabinets under sinks too.
When I Winterize I go overboard. The Walmart trailer antifreeze to excess. It's cheap.
If you blow the lines out and fill the traps with the pink stuff, if you pour in a lot in the Freshwater tank and pump the lines until it runs out in the sinks, and toilet.
That stuff might turn slushy, but in the South, that's not a problem.
BarneyS
S.E. Lower Michigan
Posted: 02/08/19 07:43am Link  |  Quote  |  Print  |  Notify Moderator
OleManOleCan wrote:
Snip...
It turns slushy in the North too but also doesn't matter as the stuff does not expand when freezing like water does. [emoticon]
Barney
2019 Ram Limited 1500, 5.7L Hemi, 4x4, SB
Not towing now.
bobndot
Posted: 02/08/19 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
RV faucets have plastic parts. It's those parts that get replaced most often from cracking.
TXiceman
Full Time RVer
Posted: 02/09/19 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
A Sprinter is not designed for 4 season use. Good luck in freezing weather.
Ken
Amateur Radio Operator.
beemerphile1
Ohio
Posted: 02/11/19 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
PEX can expand when freezing without damage but the fittings will break.
2006 Weekend Warrior FK1900
westend
Shorewood, MN
Posted: 02/12/19 11:27pm Link  |  Quote  |  Print  |  Notify Moderator
Do some inspection and diagnosis. Frozen pipes typically have a certain location where the pipes were exposed to the cold, allowing ice to form. Use accessory heat in that area and observe for dripping at fittings. It is rare to have multiple locations or a total frozen condition but is possible. Pray that your bath shower piping is still serviceable. It is a bear to restore the shower location plumbing.
Good luck on the plumbing. It was -29f at our house a couple of weeks ago. I haven't even checked the trailer as the plumbing is totally serviced (winterized). I do have to dig a walkway out to it and remove snow on the solar and check battery health. I know the batteries went into that cold fully charged but they are batteries and it was monstrously cold. All of my running fleet needed a jump start in that very cold condition. We are currently checking for land in AZ, lol.
'03 F-250 4x4 CC
allen8106
Burrton. KS
Posted: 02/15/19 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
DBHMEH wrote:
I have taken all needed precautions to prevent freezing as I'm a full-timer.
Apparently not, you didn't go far enough south. Freeze up was bound to happen.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
1983 DW (love of my life)
2010 Pit Bull Terrier (Jake)
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
