RV.Net Open Roads Forum: Adding 2nd air, converting from 30 amp to 50 amp
 > Adding 2nd air, converting from 30 amp to 50 amp
twinstick
Ball Ground, Ga
Posted: 06/17/19 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Well, today was the day my dad and I started. By the end of the day we got the AC mounted, new 50amp plug, and the AC side of the power distribution center wired. I ended up buying a new converter and pdc. Also, I'm adding a heat strip in the AC unit, and using a wall thermostat. My goal is to get this to look as close to factory as possible.
Getting the AC up, the easy way...
I had to modify the original 30amp mouse hole. I added in the new plug about the only way I could. The hole was to large to just use the 50amp plug. I made a bracket on the back and it seems solid.
Last, is where we stopped for the day. The AC side is wired, got to do the DC side, and put the new converter in. Very glad my dad was an electrical engineer and wired his house. I don't know where to begin with a lot of this.
I'll be back out in a few days. Hopefully we will be able to finish, if not, it may take an additional half day if everything goes ok.
* This post was edited 06/17/19 07:09pm by twinstick *
DavinD
Litchfield Park, AZ
Posted: 06/18/19 10:02am Link  |  Quote  |  Print  |  Notify Moderator
Pretty cool
2018 Coachman Chaparral 381RD
TV - 2013 Ford F350 Diesel SRW 4x4 Short Bed
time2roll
Posted: 06/18/19 10:38am Link  |  Quote  |  Print  |  Notify Moderator
Acampingwewillgo wrote:
Yep, that would be my way of doing it. Make the current 30 amp Panel a Sub Panel of your new 50 amp panel. Keep it simple....
And to me that seems more complicated.
Only difficult part of going to a 50a panel is pulling the 6/3 romex through any blind or inaccessible areas. Of course same difficulty in pulling 12/2 to the vent for the second A/C circuit.
675w Solar pictures back up
allen8106
Burrton. KS
Posted: 06/18/19 11:37am Link  |  Quote  |  Print  |  Notify Moderator
midnightsadie wrote:
take out the air vent some are pre wired.
A 30 amp unit likely won't be.
2010 Eagle Super Lite 315RLDS
2018 GMC Sierra 3500HD 6.6L Duramax
2010 Nights 45
2011 Nights 70
2012 Nights 144
2013 Nights 46
2014 Nights 49
2015 Nights 57
2016 Nights 73
2017 Nights 40
2018 Nights 56
2019 Nights 76
2020 Nights 20
twinstick
Ball Ground, Ga
Posted: 06/19/19 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
My dad and I were able to get it all finished up today. Got everything converted over to the 50 amp panel, and got the interior all put back together. Total, my dad and I have 2 solid days working. I've got about $1650 in everything, including swapping over to 50amp, and the new air. The new air conditioner works great, and turns our bedroom into a meat locker in no time.
Here's a few pics. On the power distribution center, the new one was actually smaller than the old one due to the converter not being made into one. I cut down the grill shroud on the old pdc, and used my plastic welder to put it on the new one. I like how it turned out. Thanks for following along.
twinstick
Ball Ground, Ga
Posted: 06/19/19 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
twinstick
Ball Ground, Ga
Posted: 06/19/19 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
DavinD
Litchfield Park, AZ
Posted: 06/20/19 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
Awesome. Nice work
jaycocamprs
Ringgold Georgia
Posted: 06/20/19 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
You won't regret either the cost, or the work.
2018 Silverado 3500 DRW
2011 Montana Mountaineer 285RLD
twinstick
Ball Ground, Ga
Posted: 06/21/19 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks. Can't wait to take it back out. I feel like it's going to be money well spent.
