RV.Net Open Roads Forum: Adding 2nd air, converting from 30 amp to 50 amp
 > Adding 2nd air, converting from 30 amp to 50 amp
Cummins12V98
on the road
Posted: 02/01/19 08:52am Link  |  Quote  |  Print  |  Notify Moderator
Prepped, add AC and on 30A, YES if the power is good you can run two AC's.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
laknox
Arizona
Posted: 02/01/19 09:03am Link  |  Quote  |  Print  |  Notify Moderator
I can see where 2 smaller A/C's could run on a 30a trailer. Maybe 2 ~8-9k units or, on older units, there were even smaller units. Even then, might still need to have a controller the sequence starting =and= hard start kits on them.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 62 Year Member
lynndiwagon
Yukon, Oklahoma, USA
Posted: 02/01/19 10:17am Link  |  Quote  |  Print  |  Notify Moderator
Your electrician Dad will know about the attractive surface mount wiring options.
Lynn & Diana Wagoner
Three Boston Terriers
2011 Chevy 3500HD, DRW, 4X4
2014 Big Country 3650RL
Retired
BarabooBob
Baraboo, WI
Posted: 02/01/19 10:23am Link  |  Quote  |  Print  |  Notify Moderator
I agree that adding surface mount would be the easiest. Some people will find the surface mounted channels to be to "industrial" looking for their liking. The electricians will know what to do. Rely on them.
Bob & Dawn Married 32 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
Cummins12V98
on the road
Posted: 02/01/19 10:49am Link  |  Quote  |  Print  |  Notify Moderator
On my last Mobile Suites I could run the 15k and 13.5 k AC’s as long as reefer and WH were on propane. No fancy switching.
john&bet
North Vernon,in.
Posted: 02/01/19 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
I have a suggestion for your electricians. Instead of R&Ring the current AC distribution panel simply put in a 50amp panel and run a 30 amp circuit to current panel and set another panel for the new air cond. leaving spaces for future add on's.
2018 Ram 3500 SRW CC LB 6.7L Cummins Auto 3.42 gears
2018 Grand Design 337RLS
Acampingwewillgo
Posted: 02/01/19 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, that would be my way of doing it. Make the current 30 amp Panel a Sub Panel of your new 50 amp panel. Keep it simple....
96 Vogue Prima Vista
The Kid's: Humphrie, the Mini Schnauzer and Georgie,wire haired dachshund, Senior Cavalier Rosie and Potter
Rainbow Bridge: Laddie,Scoutie,Katie,Cooper,Kodie,Rubie,Maggie, Cassie and Mollie, Elvis Love You!
Rally's and get togethers-Lots
Dayle1
Spicewood, Tx
Posted: 02/01/19 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
That is what I did on previous unit. An 8 slot panel (2 for the main). The existing 30 amp panel now becomes a sub panel and some of the existing circuits can be moved from it to extra slots on the new panel to help balance the load.
Surface mount wiring also is ez, Legrande plastic from Lowes can handle romex 12/2 w gnd. I used it to add a 20 amp outlet in the garage of a toyhauler from the existing A/C down to the sidewall for an electric heater. Just cut a small notch in the A/C shroud for the wire chase to exit (or in your case, enter) the A/C.
Biggest cost is the new 50 amp power cord.
Larry Day
Texas Baptist Men-Retiree Builders since '01
'13 Silverado 3500HD LT 2wd CCSB SRW, custom RKI bed
'19 Starcraft Telluride 292RLS
Rig Photos
RollandB
Albany, Or
Posted: 02/02/19 08:10am Link  |  Quote  |  Print  |  Notify Moderator
Our rig came with 30 amp and no second AC prep. Since I may add one at a point in the future as well as some additional circuits now, I updated to a 50 amp service. Had to change distribution panels for both 110 and 12v since the OEM was combined, plus the cord and ends to have the 4 wire needed. Cost was less than $300 and about 7 hours of my time. I’ve got a pretty easy path of getting the wire to the vent in the bedroom if we add the AC. Good luck with yours.
2005 Silverado 3500 Crew Cab Long Box, Duramax/Allison, B&W Companion, TST507's
2016 Artic Fox 27-5L
twinstick
Ball Ground, Ga
Posted: 06/08/19 03:39pm Link  |  Quote  |  Print  |  Notify Moderator
Bringing this back up, today was the start of my plan. I wanted to make sure I could run wires from the AC unit to the panel, and I really wanted to pull a thermostat wire to be able to use a thermostat and not one with controls on the unit. After pulling some of the camper apart, I was able to drill a few holes and run the wires.
Now to the fun fun part, I get to order parts! All in, in figuring I should have about 1500 in the conversion. I'm planning on going to 50amp and not adding a second plug. I want this to look as factory as possible. Here's a couple pics, this will be a slow process.
Edit: not sure why the picture are showing up huge
Moderator edit to re-size pictures to forum recommended limit of 640px maximum width.
Next time use this site to post your pictures. They will automatically be properly sized for use on these forums. See this thread for for instructions.
* This post was last edited 06/09/19 08:00am by an administrator/moderator *   View edit history
