RV.Net Open Roads Forum: Tech Issues: 120 not working on some outlets
 > 120 not working on some outlets
D.E.Bishop
Eagle Rock, CA
Posted: 02/02/19 07:51pm Link  |  Quote  |  Print  |  Notify Moderator
It is normal for a microwave to operate when a circuit breaker or a GFCI has tripped and the outlets on that circuit are out. Microwave ovens are normally on a separate breaker as per the Natl. Elect. Code.
As others have stated, it seems as though the whole leg is dead, indicating that either a CB or GFCI has tripped. If you have a meter, check the GFCI near the kitchen or without a meter, plug in some 120 volt appliance, table lamp from the house or a hair dryer. If there isn't any power out, I will bet it is the GFCI.
Just a little nomenclature hint, a plug is on the end of a power cord of an appliance. It plugs into the outlet. The wires inside the walls or under cabinets are usually in a cable form called Romex. You had the power cord "plugged" into an outlet that didn't work. You replaced the "outlet" and connected the wires in the "romex" to the new "outlet".
After you trip and reset all the CBs, You need to remove the dead GFCI in the circuit and see if the line side(input) is hot. If it is then you should replace the GFCI. If it isn't it's either the CB or the romex that is bad.
It's really hard to trouble shoot over the net and this is the best I can do.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
95 Suzuki Sidekick 4X4
Stowmaster 5000
1492
Arlington, VA
Posted: 02/08/19 09:26am Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Posting Help and Support
Wherever I happen to park
Posted: 02/08/19 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
An RV can have several circuits. but two things you need to understand
1: Many times the circuits are
Breaker---Outlet 1---2-3-4
or Breaker --_GFCI--2-3-4
BUT the FRIDGE (outlet .. If it is a DUPLEX. is different
One side is Shore/Generator power ONLY
The other side is INVERTER for the ice maker
So it is really two SINGLE outlets in one box. You hook 'em together. bad things happen.
Home is where I park it.
BFL13
Victoria, BC
Posted: 02/08/19 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure the replacement is the kind that both receptacles are live. There is a household kind that looks the same but one receptacle is only live when you use a wall switch and the other is always live you can plug things into it.
You might have one of those and the downstream receptacles are dead from being on the one that needs a switch.
1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
wnjj
Cornelius, Oregon
Posted: 02/08/19 06:27pm Link  |  Quote  |  Print  |  Notify Moderator
Do replacements come split? I’ve always had to break the little metal connecting tabs between the top and bottom to split them.
BFL13
Victoria, BC
Posted: 02/08/19 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure, been a while. ? I was only suggesting this as an outside possibility. This explains about your tab to break:
http://www.electrical101.com/split-receptacles.html
D.E.Bishop
Eagle Rock, CA
Posted: 02/08/19 11:34pm Link  |  Quote  |  Print  |  Notify Moderator
Okey, have you figured out what was wrong and fixed it?
bighatnohorse
Gig Harbor - Cave Creek
Posted: 02/09/19 07:36am Link  |  Quote  |  Print  |  Notify Moderator
I had that problem it it was a loose wire tie connector.
Very hard to find.
Finding it will require a VOM and good troubleshooting skills.
2014 Lance 1181
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
“Travel is fatal to prejudice, bigotry, and narrow-mindedness. . ." -Mark Twain
Posted: 02/09/19 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
I might add on Some RVs... Well here's the story
Friend came over to my Rig.. Neighbor says only half his outlets are workign.. Think you can help.. (I grabbed a test meter and headed over)
As we walked I ask him about his INVERTER Do you have one "What's an inverter" was more or less the answer
Sure enough he had one. One breaker tripped.. a quick RESET fixed it.
doxiemom11
Arizona
Posted: 02/10/19 09:44pm Link  |  Quote  |  Print  |  Notify Moderator
We had a whole leg dead once. It was the circuit breaker in the power box we were plugged in to. It was full of ants. Removed the circuit breaker. Sprayed inside the box, let it dry, then installed a new circuit breaker. All was good after that.
