RV.Net Open Roads Forum: General RVing Issues: Different generator question?
 > Different generator question?
colliehauler
Mc Pherson KS USA
Posted: 02/03/19 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
wa8yxm wrote:
Why not convert the ONAN to a portable?
Thhat Champion you cited sounds like it might be a contractor's model (That wattage usually is) ear plugs are NOT optional. they are necessary with Contractor's models.
Build a box to enclose the ONAN and load it in your truck to carry. you may wish to convert it to gasoline though.. Propane it sucks lots of.
No the champion is a inverter enclosed generator, it replaces the 3100 model with 300 more running watts and you can get it with remote start. I do have a champion 3500 open frame in case of power failure at the house, still new in the box. I need the truck bed open for a couple of maxi-scooters.
valhalla360
No paticular place.
Posted: 02/04/19 12:29am Link  |  Quote  |  Print  |  Notify Moderator
Building a rack on the tongue would be far simpler and if you bolt it in place with a cover, it won't be an obvious choice for theft. Plus you get to keep the under bed storage.
Under the bed, exhaust and heat are probably the bigger issues as opposed to noise. The portable generators are not designed to be run in small enclosed spaces.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
colliehauler
Mc Pherson KS USA
Posted: 02/04/19 06:29am Link  |  Quote  |  Print  |  Notify Moderator
The Onan is NOT a portable generator. Under bed would be no different then any other built in installation. Onan has a built in fan that sucks in cooling air and blows hot air to the under side of the RV. The exhaust runs through a tailpipe past the exterior of the RV. To install in the storage compartment you would need a sheet metal cabnet that has a lip to the outside of the RV. You would have to cut a rectangular hole in the floor for the cooling with the tailpipe running through the same opening. The generator is in it's own enclosure and designed for this type of installation. This is no different then any other built in generator installation. The Onan 2500 microlite is used extensively in truck campers and class c's. The Onan 2800 is the same generator but the gasoline version instead of propane.
I hope this clarification helps for those that don't understand.
pnichols
The Other California
Posted: 02/04/19 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
In addition for what it's worth ... Onan's meeting of National Park noise requirements apply when their models are "naked" in only their own enclosures. Built-in Onan generators can be much quieter than their naked noise specs when installed within the various RV generator compartments.
Phil, 2005 E450 Itasca Spirit 24V
colliehauler
Mc Pherson KS USA
Posted: 02/04/19 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Pnichols for pointing that out. If I install it will also go in a sheet metal cabnet covered with Dynamat noise reduction material then have the wood bed frame and mattress for additional noise reduction. I could put in additional sound insulation on the bottom and sides of the bed. You will always have a little vibration which doesn't bother me. The motor and generator are on rubber mounts inside the case.
valhalla360
No paticular place.
Posted: 02/04/19 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
I understood...I was referring to the champion on the tongue and the onan inside.
Yes, you can do it under the bed but its a little more than just shove it in a compartment and hope for the best.
badsix
north bend or.
Posted: 02/04/19 10:53pm Link  |  Quote  |  Print  |  Notify Moderator
NOPE, Champion has a 3400 inverter with remote start weighs apr. 95 #
I have the same thing only 3500w
Jay D.
colliehauler
Mc Pherson KS USA
Posted: 02/05/19 02:27am Link  |  Quote  |  Print  |  Notify Moderator
That's why I posted a detailed explanation of how to do a generator compartment. Your correct in you can't just put it under the bed. Installation of the Onan would be a little more labor-intensive.
