RV.Net Open Roads Forum: Truck Campers: Installed A Thermostatic Shower Mixer Valve
 > Installed A Thermostatic Shower Mixer Valve
NRALIFR
Truck Camping Out West
Posted: 02/03/19 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
I’ve always hated the faucet in our Lance 1121 shower. It was the typical cheepo plastic two handle model that looks like a sink faucet with a connector for a shower hose. It was difficult to adjust the temperature, so you’d waste water fiddling with the knobs.
I bought one of these several months ago on Amazon, and finally had time to install it just recently.
Thermostatic Shower Valve
This isn’t a recommendation for this particular valve necessarily, unless it will work for you. But it is a strong recommendation for this TYPE of shower mixer. It resolved all of the issues I was having with my old faucet. As I said, the temperature was difficult to set, it tended to change as the faucet itself heated up, it wasted water, and worst of all, once you got the temperature set right, if you turned the flow off at the shower head, you were blasted with freezing water when you turned it back on.
Because of space requirements, I needed a mixer valve that wasn’t any wider than the old faucet. I also needed the hot and cold inlet spacing to be no wider than the old faucet. It would actually be helpful if the inlets were closer together, to get the hot supply connector away from a vent pipe behind the shower that was partially blocking it. Most of the thermostatic mixer valves I was looking at have the valve handles pointing to the sides, rather than straight at you, so they tended to be a lot wider, and they had wider spaced inlets.
The one I bought is a much more compact design, the price was attractive, and the inlet centers are only about 2.5” apart. It was a little unique in that it needs the supply lines brought through the wall into the shower. I used the original hole in the shower wall for the cold side, and cut a new hole for the hot side. That moved the hot side supply line away from the vent pipe, and kept the flow control handle on the left side of the valve from being too close to the corner. I made a cover plate out of some FRP I had lying around to tighten up the holes around the pipes coming through the shower wall, and cover up the old hot side hole. I made the 1/2” brass piping under the mixer valve from a 90 degree elbow and a 2” long nipple.
I had to put a piece of plywood on the backside of the shower wall to give me something other than the fiberglass to mount the round support flange to. The plywood is stuck to the fiberglass with FRP adhesive.
I accessed the backside of the shower through the hole where the outside shower used to be. We’ve never used the outside shower for anything, and since this is the third time I’ve had to remove it, I’m not going to reinstall it. I’ll put the door back on, but the shower and it’s associated plumbing is going in the trash bin.
The only way I know to test out a new shower valve is take a shower, so I’ve already tested it out in my garage a few times, and it works great! The mixer valve reacts very quickly to temperature. Once the hot water reaches the valve, the temperature is maintained automatically by the setting of the right knob. To prevent scalding, the red button on that knob must be depressed in order to set the temperature any higher than 38 C (100 F). When the flow is turned off at the shower head, you no longer get a blast of freezing water when you turn it back on.
This was well worth the time, $$, and effort to do. I highly recommend it!
[emoticon][emoticon]
* This post was edited 12/06/20 06:34pm by NRALIFR *
2001 Lance 1121 on a 2016 F450
ScottG
Bothell Wa.
Posted: 02/03/19 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
Cool mod!
mountainkowboy
Socal > NE Oregon
Posted: 02/03/19 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
Nice!
Chuck & Ruth with 4-legged Molly
1990 F350 S/C Lariat Dually (Red)
1990 S&S 11SC Cabover
2011 Ford Ranger
1987 HD FLHTP
Buzzcut1
Norcal
Posted: 02/03/19 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
now pack that piping space with fiberglass batting to reduce heat loss to the TC and frozen/burst piping in cold camping and to keep the heat out on hot summer days
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
rexlion
Broken Arrow OK
Posted: 02/03/19 09:29pm Link  |  Quote  |  Print  |  Notify Moderator
I like the sound of these mixer valves. A question: once you've set your desired temperature, can you leave it at that setting for future showers? Or do you have to reset the temp each time?
Mike G.
--for now, using a cargo trailer for camping--
Those who would give up essential liberty, to purchase a little temporary safety, deserve neither liberty nor safety. --Benjamin Franklin
photo: Yosemite Valley view from Taft Point
Bedlam
PNW
Posted: 02/03/19 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
If it is like the ones I have seen, the left knob controls flow and the right knob controls temperature.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
Kayteg1
California > Nevada
Posted: 02/03/19 10:14pm Link  |  Quote  |  Print  |  Notify Moderator
It is "set and forget".
I installed several of them in the house I sold and 1 in my TC.
Since my camper has single faucet with diverted for vanity/shower - this is what I used. There is thread somewhere about the conversion.
Not only those valves make for convenience, but also save water since you can enjoy the shower instead of staying on the side and trying to adjust the temperature.
In house with tankless WH they also smooth up cold surge on restart.
valhalla360
No paticular place.
Posted: 02/04/19 03:19am Link  |  Quote  |  Print  |  Notify Moderator
It's still a nice upgrade as it eliminates all fiddling...
But if you shut off between soaping up, I usually use the button on the shower head rather than the hot/cold valves...that way when you turn it back on, the temp is set the same...your mixer is still better as you still have to adjust the values when you first turn on the shower but mid shower, you shouldn't have to worry about adjustments.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
NRALIFR
Posted: 02/04/19 03:31am Link  |  Quote  |  Print  |  Notify Moderator
That’s correct. I’ve been leaving the right hand knob up against the red button stop, which gives you 100 degree water all the time. Twist the left hand flow control knob to turn the water on and off. If your shower head has a shutoff valve, you can use it to control the water flow while showering, and just leave the faucet flow control valve fully open.
ScottG
Bothell Wa.
Posted: 02/04/19 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
I'm going to do this mod. I found another faucet that retains the bathtub fill feature and/or allows you to drain the shower hose after use. Link
I'm curious though; what happens when it starts running out of hot water?
* This post was edited 02/04/19 02:46pm by ScottG *
