RV.Net Open Roads Forum: Class C Motorhomes: Washer dryer in a class c
 > Washer dryer in a class c
Chum lee
Albuquerque, NM
Posted: 02/06/19 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
maillemaker wrote:
It's cheaper just to RV naked. Neighbors look at you funny though. [emoticon]
Not if you are staying at De Anza Springs (RV) Resort in Jacumba, CA. And, FYI, it's about middle of the road price wise. They do have a coin laundry, or, you can bring your own.
Chum lee
Byork
N. IN
Posted: 02/07/19 06:07am Link  |  Quote  |  Print  |  Notify Moderator
OLDROADDOG wrote:
Anybody install a washer dryer in a class C MH?
My wife just purchased a Zeny Mini washer/dryer combo for our class C.
It's small and fits in our shower which should make it easy to drain. I think it's less than 30 lbs. We haven't used it yet, but thought it might come in handy since we have a 1 and 3 yr old.
It doesn't actually dry, just spins the water out, then you have to hang dry. But, for $89 I feel like we can't lose.
2000 Chevy Yellowstone Sport 30', class C
bobndot
Posted: 02/07/19 09:49am Link  |  Quote  |  Print  |  Notify Moderator
We used one, it worked well enough to keep us out of laundromats. [emoticon]
We would make bets with each other to see how many minutes a clean set of clothes would remain clean on out daughters. We needed to dry stuff faster in order to keep the clothes in rotation.
The campfire was our dryer.
We used our Sports-brella to reflect the heat to dry the clothes faster. The umbrella spokes are sturdy enough to hang the clothes using hangers. Everything dries quickly with it pitched and staked down at a 45' angle. Well worth it to make your rv life more simple when you have kids going thru clothes all day.
We carry an old round fire-ring pan from an old outdoor fire-place. It acts as a canopy for the campground fireplace which allows us to have a campfire in the rain and still dry the clothes.
The sports-brella which reflects heat , can also be used as a warm cozy wind block on your back while sitting at the campfire. You can leave it in the same position for drying or sitting. Two people sitting in chairs can stay dry in a light rain sitting under it . It's been an asset to our washer and our campfires. [emoticon]
Byork
N. IN
Posted: 02/07/19 10:04am Link  |  Quote  |  Print  |  Notify Moderator
That's good feedback and good ideas. Thanks!
sprint99
Merton, WI
Posted: 05/09/19 08:31am Link  |  Quote  |  Print  |  Notify Moderator
Re-kindling this topic as the wife just recently brought up about adding a Washer Dryer Combo to out Class C. We DO have the Leprechaun 311FS and I have contacted Coachmen whom did reply back that all the provisions are in place to add. I will of course pull the panel to confirm. Also have to see how much effort and pain in the butt it will be to remove the door and casing to move a unit the area it's meant for.
From what I read up on, these non-vented combo units use a lot of water per wash and dry cycle, so would for sure want to be at a full hookup site when doing multiple loads. Wouldn't be too big a of deal there for us and also know that we could get away with a load utilizing the fresh water and gray tank.
She's pricing some units now, so we'll see if this proceeds.
Racine96
Racine
Posted: 05/12/19 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
I have 311FS that did not come with it installed. If you remove the rear panel in the closet, you will see that everything needed is already installed. However, I installed a Splendide vented. I did a hole in the outside wall. It works fine. You need to put the water heater off in order for it to work. I turn it off while using the washer. The unit comes with a separate valve and connection for the used water, so you need to be hooked on a site. It does not go the grey tank. If you get under your unit, you will see it. Look at the link below and you will see photos of it installed and the exhaust vent.
http://www.forestriverforums.com/forums/f230/my-first-class-c-134789-15.html
