RV.Net Open Roads Forum: Travel Trailers: Old tires?
 > Old tires?
drsteve
Michigan
Posted: 02/06/19 08:14am Link  |  Quote  |  Print  |  Notify Moderator
My 2003 Jayco (that I purchased new) came with a set of Goodyear Marathons. They lasted for 13 years.
1991 Palomino Filly PUP
prichardson
Lafayette, La
Posted: 02/06/19 08:17am Link  |  Quote  |  Print  |  Notify Moderator
Highway (auto & LT) tires are manufactured to different standards than ST tires.
Both will age out. I have yet to be able to dependably get more than 4 years on STs; but have no problem getting 8 to 10 on highway tiers.
Redterpos3
Binghamton, NY
Posted: 02/06/19 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
I learned the hard way. 7 yrs is the MAX! Replace at 6 to be safe, is my mantra now!
The Travelin' Terrapins!
2016 Ford F-350 SRW;CC;4x4;172WB;6.7PSD;34,000m
2011 Nash 27T 12,995m
2013 Yr1 30nts 3150m
2014 Yr2 52nts 3365m
2015 yr3 25nts 2260m
2016 yr4 46nts 2500m
2017 yr5 24nts 1720m
2018 yr6 4nts 30m
CavemanCharlie
Storden,MN
Posted: 02/06/19 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
waynefi wrote:
I must be really lucky, since I've gotten almost 8 years and 30000 miles out of a pair of cheap Chinese tires.
It helps that the trailer is light, and when I'm not camping it is parked in a shady spot.
I'm surprised that so much of this is about years, not miles. I don't replace car tires after 3 years, I look at miles and tread.
My cheap chinese trailer tires are 9 this year. I too have a light trailer, I stay close to home, and I only go down 2 lane roads at no more the 65 MPH. I think I will run them another year. Unless, I do a long trip then I would replace them.
Posted: 02/07/19 11:55am Link  |  Quote  |  Print  |  Notify Moderator
wiskeyVI wrote:
What about using a good Light Truck Tire, load range E?
IF they existed, this may be a good option, but 14" heavy LT tires don't exist and 15" are few and far between if at all available anymore, last I checked.
03 Arctic Fox 860
07 Dodge 2500 deezul
"Obviously I don't want to overload my truck and be unsafe, but the reality is the truck is way more capable than the 10K GVWR they put on the sticker.
KJ"
Posted: 02/07/19 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
Wayne, on one hand, yes you got lucky. On the other, you got kinda lucky.
There's real truth to the replace every 3-5 years theory. (3 years is excessive IMO, but there's actually a guy on here who changes his trans fluid every 500 miles too, so....)
I've had china bomb trailer tires last as long as your's. I've had 4 year old tires blow treads off them. Have had 10 year old tires that worked fine still, got beat on and then blew up in the driveway.
Bottom line, I personally wouldn't go more than 5 years, but loading, wear, care, heat all play a part in tire life. Knock on wood, I've never actually lost a tire in the winter when weather was cold and I tow almost as much in the winter some years as summer.
8 years, 30k, yeah buy some new ones. FWIW, I have the same tires as you on both of our tandem axle trailers. 14" Rims. Kenda Karriers have dun gud so far. I'd buy Karriers again based on my experience with them thus far.
waynefi
S E Michigan
Posted: 02/07/19 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
There's another way of looking at this. If a tire fails in 3 years of normal use, it was defective anyway. Age had nothing to do with it. If it's still OK after 3, you got a good one. Keep it for 3 more.
I'll admit that 8 might be pushing it.
Rockwood MiniLite 1809S
Tacoma V6
Terryallan
Foothills NC
Posted: 02/07/19 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
Not so. ALL of my TT tires blew in their 4th year. That is why I won't allow 4 year old tire on my TT any more. Not even on the spare rim.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
deltabravo
Spokane, WA
Posted: 02/07/19 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
Here's my old tires
I changed them out to Goodyear Endurance
2015 Nash 17k (bought pre-owned 5/23/18)
twodownzero
NM
Posted: 02/08/19 07:54am Link  |  Quote  |  Print  |  Notify Moderator
deltabravo wrote:
Here's my old tires
Good choice. I just bought a set of the same tires.
 > Old tires?
