RV.Net Open Roads Forum: Fifth-Wheels: Sewer smell
 > Sewer smell
Elwoodj
Decatur, Ga
Posted: 02/04/19 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
I need help to eliminate a sewer smell coming from the sliding door area going upstairs in our fifth wheel. The door is on the opposite side of the toilet. There are no leaks. I have looks underneath in the storage area and still cannot find the source.
Elwood & Kathy
36' CK3 Mobile Suite - 2006
2004 Dodge Ram Cummins 6 speed
HO 600 373
ScottG
Bothell Wa.
Posted: 02/04/19 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
You may have a vent that is pulled up out of the tank.
If nothing else, use chemicals to stop the smell.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
garyp4951
TN
Posted: 02/04/19 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
Might be a screw on vent cap under the sink thats not sealing.
San Simeon area, California
Posted: 02/04/19 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
Looks again. A plugged vent is my guess.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
SidecarFlip
SE Michigan
Posted: 02/04/19 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
Quit farting in the bedroom....lol
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
mtofell1
Oregon
Posted: 02/04/19 09:03pm Link  |  Quote  |  Print  |  Notify Moderator
Get a clear fitting. Dump, fill with some water, dump, fill, repeat until it runs clean. You will likely be amazed at how much "stuff" is left in the tank with just a simple dump. I have to fill/dump several times to get it all out. And before all the backseat campers ask, yes, I am using plenty of water to start with after a dump and during usage.
valhalla360
No paticular place.
Posted: 02/04/19 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
Check the vents are clear and the traps hold water.
What is in the tank should have no impact on what you smell inside.
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
MudChucker
Niverville Manitoba
Posted: 02/05/19 05:23am Link  |  Quote  |  Print  |  Notify Moderator
Is there a tank vent near a roof vent?
Hit up a dollar store and buy some pinesol like ten bottles of it, as mentioned above, get a clear sewer line fitting and dump file rinse repeat until everything is out then dump a gallon or two of pinsol in and leave it for a while.
I do this a few times a season and try to drive with the cleaner in the tank. Downy scent Perls or what ever the are called are good to.
I dump about 10 bottles for the winter season.
2017 Cougar
2015 Ram 3500 Megacab 6.7 Cummins Aisin transmission
JusBud
Right Here
Posted: 02/05/19 05:46am Link  |  Quote  |  Print  |  Notify Moderator
I know you said you checked for leaks but it doesn't take much to get that smell.
Gray tanks need to be cleaned too or else they'll get the same smell
RollandB
Albany, Or
Posted: 02/05/19 07:25am Link  |  Quote  |  Print  |  Notify Moderator
We had the same type of steel in the kitchen area caused by a faulty air admittance vent under the sink. Replaced it, smell was gone.
2005 Silverado 3500 Crew Cab Long Box, Duramax/Allison, B&W Companion, TST507's
2016 Artic Fox 27-5L
 > Sewer smell
