RV.Net Open Roads Forum: Looking at buying a portable black tank - suggestions?
 > Looking at buying a portable black tank - suggestions?
Dave&Jeanette
Westminster, MD
Posted: 02/05/19 07:16am Link  |  Quote  |  Print  |  Notify Moderator
We are looking at buying a portable tank in order to be able to dump our tanks when staying at a site for more than 7 or 8 days without sewer hookup. Our black tank is 50 gallons and the largest one I see is 42 from Barker. I know some will say that we could use the facilities at the camp ground, but much prefer our own.
Thanks for any input.
Dave
2015 Ford F350 CC DRW 6.7L PS Diesel
2016 Grand Design Solitude 379FL
Mfan
Otsego,Mi
Posted: 02/05/19 07:32am Link  |  Quote  |  Print  |  Notify Moderator
Those are big. Think about how many times you are going to use it. I'd suggest a smaller one and empty every few days.
donn0128
Pronounced Ore-gun
Posted: 02/05/19 08:08am Link  |  Quote  |  Print  |  Notify Moderator
That 42 gallon tank when full is foing to weigh north of 350 pounds. How are you going to move it? Heck, a 20 gallon tank is a struggle over rough ground.
Boomerweps
Hills of PA
Posted: 02/05/19 08:10am Link  |  Quote  |  Print  |  Notify Moderator
Only thing worse than a hugely heavy water container to move is one full of ****. You want to move and try to dump way over 300# of ****!
2019 Wolf Pup 16 BHS Limited
2008 Ford Exploder 4.0L
camperdave
northern, California
Posted: 02/05/19 08:30am Link  |  Quote  |  Print  |  Notify Moderator
What on earth are you eating that you can fill up a 50 gallon black tank in 7 days!?! [emoticon]
2004 Fleetwood Tioga 29v
js218
on the road
Posted: 02/05/19 09:10am Link  |  Quote  |  Print  |  Notify Moderator
I can go a month with 75 gallon black tank.
2017 Haulmark 45' Super C 600hp, 12 speed I shift transmission, tandem drive axles, 3 stage engine brake, towing 26' trailer with an 08 explorer inside.
Jim
2oldman
Salton Sea
Posted: 02/05/19 09:19am Link  |  Quote  |  Print  |  Notify Moderator
Hint: don't try to dump it all at once.
Fizz
Ottawa, Canada
Posted: 02/05/19 09:35am Link  |  Quote  |  Print  |  Notify Moderator
I have a 15 gallon, 120 lbs when full and I wouldn't want to handle anything larger.
Jebby14
Windsor Ontario
Posted: 02/05/19 09:40am Link  |  Quote  |  Print  |  Notify Moderator
for what its worth, when you realize you want a smaller tote and are only going dump often. be VERY diligent that you don't have more in the tank than the tote can hold. otherwise you're bound to have a crappy time
If it moves and it shouldn't..... duct tape
if it doesn't move and it should.....WD40
if all else fails .....BFH
Dick_B
Palos Heights, IL USA
Posted: 02/05/19 10:06am Link  |  Quote  |  Print  |  Notify Moderator
Maybe it's my hangup but I don't use my blue tote for Black Tank contents because, IMHO, there is no way to clean it sufficiently to keep it from smelling up the area where it is stored.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
