RV.Net Open Roads Forum: Class C Motorhomes: Ford cup holder
 > Ford cup holder
suprz
rhode island
Posted: 02/05/19 10:39am Link  |  Quote  |  Print  |  Notify Moderator
Is it true that the cup holder portion of the engine cover will just lift up and come off? (2006 E450)
Proud father of a US Marine
DrewE
Vermont
Posted: 02/05/19 11:08am Link  |  Quote  |  Print  |  Notify Moderator
The center console part will, yes. There are one or two latch lever spring things that must be pulled out away from the doghouse and then it slides up and off. Look for a little black metal tab thing sticking out (I think the bottom of the console unit, but it might be the top).
The storage console units are interchangeable across quite a few years, so if you find one in a junkyard with holes and compartments that you like better than yours it's a very simple job to upgrade. I should see about doing that sometime; the '98 that I have uses about the least handy arrangement they managed to come up with.
camperdave
northern, California
Posted: 02/05/19 11:37am Link  |  Quote  |  Print  |  Notify Moderator
yeah, it just slides off vertically. No need to remove the doghouse. Here's a post I made about changing mine a little while ago.
What did you do to your Class C MH today???
2004 Fleetwood Tioga 29v
ron.dittmer
North-East Illinois
Posted: 02/05/19 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
Yep, just feel below for the spring steel clip. Pull it away from the engine shroud while lifting and the cup holder comes right up and off.
And like has been shared, it seems to be "universal" being able to change styles of cup holders. I know my 2007 4 cup holder design is interchangeable with the current-day 2-cup / two lower compartment version.
* This post was edited 02/05/19 02:09pm by ron.dittmer *
2007 Phoenix Cruiser model 2350, with 2006 Jeep Liberty in-tow
carringb
Corvallis, OR
Posted: 02/05/19 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
I put a 2009 center console in my 2000. Completely interchangeable, except the 2009 console had slightly thicker mounting tabs, so I had to back out the retaining screws in the doghouse a half turn.
Bryan
2014 ORV really big trailer
2015 Ford Focus ST
Home Skillet
Pearland Texas
Posted: 02/05/19 08:19pm Link  |  Quote  |  Print  |  Notify Moderator
Same thing I did on mine.
Makes access to the camper so much easier.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
sullivanclan
Grand Junction, Colorado
Posted: 02/12/19 11:59pm Link  |  Quote  |  Print  |  Notify Moderator
I just changed mine out to the smaller unit that affords lots more room for your feet as you move from the front seats to the back. I bought mine on Ebay for $140, in great condition, and will now turn around and sell my larger one. There were at least two or three more on Ebay. One of the best upgrades I have made to keep the wife happy! (Just as Home Skillet showed in his photo)
2003 Ford 450 Jayco Greyhawk 25D
1986 Jeep Renegade
2011 Jeep Unlimited Rubicon JK
VA-Apraisr
glen allen, VA
Posted: 02/13/19 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
Is the smaller one installed missing the 4th cupholder? I like the large/small choices in my 2003 unit, but don't like the difficulty with moving to the back.
ron.dittmer
North-East Illinois
Posted: 02/13/19 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
We have this cup holder that Ford used through 2008. The 4 cups are the same size. As you can see, it does not get near the floor allowing for driver and passenger foot room to swing inward to get into the house. The top-middle triangular hole holds the removable ash tray cup-thingy that we use to hold change.
Here is the design from 2009 to today. It has two cup holders, but has nice top trays and also a second lower right-side cubbie. What looks like a smaller 3rd cup holder on the far left, I believe holds the removable ash tray.
As far as which design is better. I always thought the latest design would be ideal, but when on trips we use all 4 cup holders for two types of drinks for each of us. So maybe our older 4-cup holder is better for us.
VA-Apraisr
glen allen, VA
Posted: 02/14/19 06:16am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, good to know but like having the 4-cup holder option and the closing door storage at the bottom. Thanks for the above photos for comparison!
 > Ford cup holder
