RV.Net Open Roads Forum: General RVing Issues: truck stops
 > truck stops
Page of 6
F450
Carmel Valley, CA
Posted: 02/05/19 01:11pm Link  |  Quote  |  Print  |  Notify Moderator
It is such a pain to go into a big truck stop and have to go in and give them my credit card. Why can't you use the credit card machine out at the pump?
the bear II
Torrance CA.
Posted: 02/05/19 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
They want you to buy groceries, snacks, accessories, books on CD...etc.
missnmountains
Southwest Florida
Posted: 02/05/19 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
Flying J has a debit card for rvers. With the goodsam and the debit card you receive 14 cents off per gallon at the truck lanes.
Ken
2016 Newmar Dutch Star 4369
Our Blog: Lawrence Adventures
Cummins12V98
on the road
Posted: 02/05/19 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
It’s really simple. Send the wife in to pre pay. She can do some shopping. You fuel, give her two rings n hang up. You pull forward, she pays. Now get back on the road.
See how EAZY that is???
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
IB853347201
Eastern Ontario
Posted: 02/05/19 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
I don't understand your issue. Why doesn't your credit card work at the pump? Mine does and so do most people I've talked to.
Are you trying to use a prepaid visa card?
BarabooBob
Baraboo, WI
Posted: 02/05/19 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
My wife and I have travelled over 20,000 miles in the last 4 years while either driving an RV or towing a TT. I have never had an incident where my credit card did not work at the pump, except at a gas station in the middle of Montana that had very, very old non-digital pumps and I had to pay inside. We charge ALL of our fuel on my credit card while travelling. Never had a problem at a modern station.
Bob & Dawn Married 30 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
buc1980
houston tx
Posted: 02/05/19 04:11pm Link  |  Quote  |  Print  |  Notify Moderator
I consider is a hassle to prepay and then go back to get the recipe.And then the fuel is more expensive than the regular gas station.I don't fuel there.
2017 Ford F350 DRW,2005 Kountry Star 35ft,14750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.
Wherever I happen to park
Posted: 02/05/19 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
Normally on my LONG DISTANCE hikes I use Flying-J's (or cracker barrel) as an overnight. Most J's have special RV islands usually in the 'AUto" section (Front of the store) and Truck pumps in the back.
There will be TWO RV lanes. Total 4 pumps (one two sided and two one sided) or one two sided pump with two "Slave" hoses.
THis way you pull in between two pumps and can fill from either side
These will take your credit card. and dispense both Gas and Diesel
The only thing I DO NOT like about them is it is often a bit 'tight" for my taste getting out. Have yet to have a problem but.. Not always comfortable.
IN addition at least one of the AUTO isles will have Dieses and take your credit card.
The Semi islands (Back of the store) only take Fleet cards.
Oh. and Loves. TA and Pilot (Even though J and Pilot are the same companies Pilot does not have RV lanes or parking as a rule) Usually at least one automotive island will have Diesel.. I use the auto islands for my gasser.
OH and to date I've seen Three J's without RV islands though one the auto section was tore up for revision.
Home is where I park it.
tracyb-oh
Cincinnati,Ohio
Posted: 02/05/19 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
This is exactly what we do. Usually there is a Wendy’s, Subway , or such. I’ll pick up lunch and we are on our way in no time. No big deal.
Tracy and T
2017 Sanibel 5th wheel
2015 Dodge Ram crew cab long bed Cummins diesel
JaxDad
Greater Toronto Area
Posted: 02/05/19 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
If you’re only driving the equivalent of a cube van why are you not just using a normal gas station like the rest of the country?
Page of 6
 > truck stops
