RV.Net Open Roads Forum: General RVing Issues: tpms
rbp111
Citrus Heights, CA
Posted: 02/05/19 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
I am thinking of buying a TPMS, a Tire Pressure Monitor System. Is it recommended for a fifth wheel trailer? And which one would you buy?
donn0128
Pronounced Ore-gun
Posted: 02/05/19 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
Brand? Does it matter as long as the one you select is capable of receiving signals from your trailera tires. People swear by them. But I personally would skip it unless I was towing with cheap ST tires.
Ltrip
Reno, NV
Posted: 02/05/19 04:29pm Link  |  Quote  |  Print  |  Notify Moderator
This question has been asked and answered numerous times in numerous threads.
I believe that TPMS will eventually save your fifth wheel from damage due to a blow out. I won;t leave home without it. I had it on my fifth wheel and it warned me of a blow out at least 3 times. I was able to stop and change the tire before it disintegrated and damaged my trailer.
I use TST and am very happy with it.
Cheers,
Larie Trippet Reno/Tahoe region
2018 Ford F250 Lariat Ultimate CC SB 4X4 diesel
2018 Arctic Fox 25Y
2014 BMW R1200GSA
fj12ryder
Platte City, MO
Posted: 02/05/19 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
Look at a TPMS as another RV insurance: you hope you never have to use it, but you'll be glad you have it if you need it.
I like the TST system, but it's the only one I've ever used. I'm not too crazy about the long lag time between sensor loss and notification of such. But I'm moved the monitor around in the cab and don't seem to be plagued with signal loss any more.
Howard and Peggy
"Don't Panic"
Acampingwewillgo
Posted: 02/05/19 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have one yet BUT I realize the need for it! I watch my rear camera on the MH all the time fearing that my "toad" has had a Blow out which I wouldn't know about until plenty of damage was done. Same goes for the inner of dual wheels....you could drive 100's of miles without knowing you loss pressure on an inside tire.
I'm talking myself into it!!! :-)
96 Vogue Prima Vista
The Kid's: Humphrie, the Mini Schnauzer and Georgie,wire haired dachshund, Senior Cavalier Rosie and Potter
Rainbow Bridge: Laddie,Scoutie,Katie,Cooper,Kodie,Rubie,Maggie, Cassie and Mollie, Elvis Love You!
Rally's and get togethers-Lots
Boon Docker
Posted: 02/05/19 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
I have been using Tire Tracker for 5 years and I am quite pleased with it.
Dutch_12078
Winters south, summers north
Posted: 02/05/19 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
We've been very happy with our TST 507 system, and we were happy with the 510 system that preceded it. It has alerted us to tire leaks and a failing wheel bearing on our toad, and sticking wheel cylinders on both the toad and coach. It has more than earned its keep...
Dutch
2001 GBM Landau 34' Class A
GTO66
Posted: 02/05/19 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
I also use the TST 507 system.I like it so much I leave the ones on the truck all the time lets me know if the tires need air. I have found it to be real accurate.
Ron3rd
Upland, CA USA
Posted: 02/05/19 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
Tst 507 is what I have also, purchased about 6 years ago
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
EgorKC
Kansas
Posted: 02/05/19 08:14pm Link  |  Quote  |  Print  |  Notify Moderator
We have used the Tire Minder system for 7 years. It has alerted us twice that required attention, Awesome. It was not fast enough to alert us on a tire tread separation blowout at 65 on the highway, Not so good. It has alerted me falsely twice, worth a manual check. It is just another tool in the box. I still check PSI before trips manually.
I do check the tire status often while on the road and check temperatures as well as PSI. Only you can decide if the $ is worth it. I felt it was. Just do not count on it by itself. A high quality PSI gauge cannot be beat.
Greg, camp chef.
You cannot stop growing old but you don't have to grow up. ">
Chef/Pilot
DW/Navigator
2 Sons, 1 DIL, 2 Grandsons, 1 Granddaughter. Boz the cat">
2012 F350 XLT 6.7 Powerstroke 4X4 SWD Crewcab.
2012 Wildcat 313RE-OK
