RV.Net Open Roads Forum: Class A Motorhomes: Dead batteries woes
 > Dead batteries woes
lamoz1
Van nuys , CA
Posted: 02/06/19 10:27am Link  |  Quote  |  Print  |  Notify Moderator
Hello
Well I've been at it for months now and cannot figure what is draining both my house and chassis batteries. 99 bounder with a cut off switch for both. I cut off the chassis battery and can hear a click at the control box. Most things shut off, like the ignition and power step, but have noticed it still has power to the cigarette lighter, LP detector, power to the generator and maybe the fridge. I don't think the cut off switch does anything to the house batteries. Both batteries are less than 4 months old, a marine rv for house and regular battery for chassis. I turn the generator at least 1hr per day to keep them topped off but sometimes I come to find one battery dead or both in less than
a day. I've use a multi meter to find a drain and I get none. When running the generator my chassis battery is not getting charge, instead is being drained as is connected to the generator and needs 12v to run if I'm not mistaken. This whole issue is making me pull my hair, since I will be living in it for a few months with no shore power.
suggestion are welcomed. Thank you
Wherever I happen to park
Posted: 02/06/19 10:43am Link  |  Quote  |  Print  |  Notify Moderator
First: IF the batteries are disconnected.. In "Store" mode. they WILL NOT CHARGE and in fact the generator should not start either.
If the batteries are not being charged by the generator first check the breakers on the Genny. Should be two. if your rig is 50 amps one runs half the RV the other the other half ONE runs the converter. (It is on one or the other halves)
On a 30 amp RV one runs most everything the other one A/C.
Then check the breaker box. Make sure you don't have a tripped CONV breaker (I've had that)
IF like mine your converter is a "plug in" model. Make sure it's plugged in (YES I've had to do that several times)
Now we test the converter itself. And post the results.
Measure output voltage
There may also be a fuse or trippe circuit breaker in the line.
IF you have a big INVERTER/CHARGER.. Well post that and we will modify the sequence.
Home is where I park it.
path1
Varies with weather
Posted: 02/06/19 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
* This post was edited 10/24/19 10:29am by path1 *
RLS7201
Posted: 02/06/19 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
In your RV Custom Products Battery Control Center (BCC) is a silver isolator relay. It is probably the reason your chassis battery is not charging when on generator or shore power. It will also keep your house batteries from charging when the engine is running. That relay has a high failure rate. When replacing, make sure you purchase a "Continues Duty" relay. The 2 battery bank disconnect relays are also in the BCC. They are in a black plastic housing.
The cigarette lighter and propane detector are intentionally left connected, by Fleetwood, when the batteries are disconnected.
When you push the AUX battery cut off switch to off, the house batteries should be disconnected.
Your propane detector is powered from both battery banks.
Richard
95 Bounder
* This post was edited 02/06/19 02:38pm by RLS7201 *
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
MrWizard
Traveling
Posted: 02/06/19 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
I don't know how much Battery power you use everyday
But I can tell you
With me, the pc, lights, furnace to stay warm
One hour is not enough generator powered converter charging time
And I have a 75 amp charge converter
Yours is possibly 45 amp
With the rainy cool weather, you might need 3 to 4 hours everyday
And a 8 to 10 hour run one day a week
Batteries have to brought back to full complete charge at least once a week When full-time,
and that means they reach a charge state of less than 1 amp going in. with a voltage above 14.4v at the batteries
Continued partial charging everyday just means the batteries performance fades as they slowly Die
Radiate The Happy
1997 F53 Bounder 36s
twodownzero
NM
Posted: 02/06/19 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
I have 400 watts of solar and my batteries are never dead. Plenty of extra juice. I can even check battery status with my phone, bluetooth. But if you have a drain and not just more load than you're replenishing, or bad batteries, solar won't fix it.
Gjac
Milford, CT
Posted: 02/07/19 09:39am Link  |  Quote  |  Print  |  Notify Moderator
The easiest way to resolve your problem is to disconnect your neg cable and measure the amp draw between the neg cable and neg post by inserting the leads of your multimeter between the two on the 10 amp scale with the MH not plugged into shore power. If you see more than an amp, say 2 or 3 amps start pulling your 12 v fuses until you see the amp draw bellow 1 amp. You may find that something is left on. If on the other hand you see less than 1 amp I would suspect that you have not fully charged either your house or chassis batteries. Do you have a portable battery charger? Most portables charge at least 10 amps. What type and how many amp converter charger do you have on board your MH? On older MH's they may only charge at 5 amps. Charge until both batteries say full then disconnect the neg cable, if the batteries are good they should hold a charge for several months. Let us know how you make out.
* This post was edited 02/07/19 09:45am by Gjac *
MrWizard
Traveling
Posted: 02/07/19 10:20am Link  |  Quote  |  Print  |  Notify Moderator
My 97 Bounder , 36ft with slide out, came with a 55 amp converter, but it was only 13.8v
I suspect the OP has something similar
My converter is in the outside bay/compartment under the kitchen, next to the entry door
The (2) 6v house batteries are up front behind the grill
The voltage at the batteries was always too low for a proper charge
I changed the converter to a power max adjustable voltage 75 amp model
And then added a third battery, a 200 ampHr deka 4d AGM
I put it in the compartment, it's a sealed a AGM, and there is ventilation in the compartment
steved28
Bellingham,MA,USA
Posted: 02/07/19 12:21pm Link  |  Quote  |  Print  |  Notify Moderator
Clamp-on DC ammeter. Best investment I ever made in tracking down current draw.
2019 Winnebago Sunstar LX 35F
2000 Jeep Wrangler TJ Sahara
lamoz1
Van nuys , CA
Posted: 02/07/19 12:58pm Link  |  Quote  |  Print  |  Notify Moderator
I will check on all this on Saturday. I notice some people use (2) 6v batteries. Is there
and advantage to this? I'm using a single 12v but have bought another one so I'll be running (2)
12v batteries for the house.
