RV.Net Open Roads Forum: Fifth-Wheels: Brakes are NOT working
 > Brakes are NOT working
klr650goldwing
minnesota
Posted: 02/06/19 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
We are at an RV park in Terlingua, TX. The brakes on the 5er are not working. I have the Curt 7-way RV blade style plug tester. It says the BK (electric brakes) terminal has no power. I checked all the fuses, they look good. The wiring seems normal. Can you give me any ideas what to check next? Is there a RV repair person in these parts? I googled and found one guy, who doesn't answer his phone. Thanks.
2011 Crossroads Cruiser, CF325CKP
2004 F350, V10, CC, LB, 4X4, 456
2004 Honda Goldwing GL1800
2004 Kawasaki KLR650
1966 Honda 305 Dream
romore
Okanagan valley British Columbia
Posted: 02/06/19 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
Is the controller indicator light on? Maybe a connection is loose. Did you check the brake fuse with a VOM?
klr650goldwing
minnesota
Posted: 02/06/19 12:59pm Link  |  Quote  |  Print  |  Notify Moderator
I checked all fuses with a voltmeter and key on. All fuses had voltage on both sides of the fuse. The controller light is on.
1995brave
San Antonio, TX
Posted: 02/06/19 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
Do the other lights work on the rv, tail turn signal, etc. ? If they don't check for a loose ground on both the truck and rv side.
klr650goldwing
minnesota
Posted: 02/06/19 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
All other lights/systems work as they should. Could the brake controller be bad?
the bear II
Torrance CA.
Posted: 02/06/19 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
I had the wire nuts come loose from the brakes to the 5th wheel wiring harness a couple of times. But it was only one wheel each time just offering as a possibility. Make sure the connections are good at each wheel.
1995brave
San Antonio, TX
Posted: 02/06/19 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
It could be the controller. What brand and model?
CoeyCoey
Colorado
Posted: 02/06/19 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure someone is manually applying the brake controller when you test, otherwise voltage will be zero. If it still tests at zero, then it is the wire, the brake controller, or the brake controller power. If still zero, check the output from the brake controller when applying it manually. If it shows voltage, then it is the wire. If no voltage, then it is the brake controller, or its power supply.
BarneyS
S.E. Lower Michigan
Posted: 02/06/19 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
I would check at the office of the park you are at. I bet they know of a reliable mobile RV tech that they call. Good luck.
Barney
2019 Ram Limited 1500, 5.7L Hemi, 4x4, SB
Not towing now.
MarkTwain
Northern, Ca. , USA
Posted: 02/06/19 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
Barney
OR, if you have Good Sam Road Side Service, you might call them and ask them to locate a mobil repair shop or if needed, limp your trailer into a RV repair shop.
