RV.Net Open Roads Forum: Tech Issues: I messed up removing an evap cooler
 > I messed up removing an evap cooler
SHRED
Encinitas, California
Posted: 02/06/19 02:20pm Link  |  Quote  |  Print  |  Notify Moderator
My plan was to remove the evap cooler and install a Fan-Tastic fan.
As you can see from the pic I got carried away and accidently tore the aluminum roof on one side.
I have putty tape and Dicor lap seal for the job.
What would you do?
I am planning to install (with screws) and putty tape then I guess I will get generous with the Dicor to cover the mistake?
1995 Lazy Daze 23.5 TK
the bear II
Torrance CA.
Posted: 02/06/19 02:27pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a good plan
dougrainer
Carrolton, Texas
Posted: 02/06/19 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
You get a flat 3/16 aluminum plate just slightly larger than the imprint of the exposed area. You then use Dicor rood sealant and liberally seal the inner edge of the flat plate and use either rivets or flat head screws to anchor the plate. Make sure you cover the existing hole from the inside to prevent Dicor from oozing out and falling down into the interior. The Dicor and screws will glue the plate securely and will not leak and no need for Eternabond. Then from the inside drill 4-- -1/2 inch holes at each corner of the old wood square and then cut your 14 by 14 inch hole in the aluminum plate. You have a good repair that will support anything and you can attach Anything to that plate. If you want after the Fantastic install just use extra Dicor to cover the added plate and nobody will know what you did. Doug
ScottG
Bothell Wa.
Posted: 02/06/19 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
I would cover it with Eternabond, not putty and goop.
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
Pirate
Northeast Tennessee
Posted: 02/06/19 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
Eternabond.
Pirate
Northeast Tennessee
Eternabond.
SHRED
Posted: 02/06/19 06:26pm Link  |  Quote  |  Print  |  Notify Moderator
I ended up cutting a 4.5" x 17" piece of flashing and gluing it down.
1995 Lazy Daze 23.5' TK
RJsfishin
Winston Or.
Posted: 02/07/19 08:00am Link  |  Quote  |  Print  |  Notify Moderator
I would have installed the fantastic, and then oil base sealed any exposed, then Eternabond over it all.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
SHRED
Posted: 02/11/19 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
Came out good.
I laid down a good bead of 3M 5200 fast cure and installed it.
Just to be sure I also used the 5200 around the plate edge.
