RV.Net Open Roads Forum: What about those houses with RV Garages
 > What about those houses with RV Garages
Big Katuna
Deland, FL
Posted: 02/07/19 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
This website advertises RV Barn/house plans.
I never checked into prices.
Uncle Howard’s Kits
My Kharma ran over my Dogma.
Hammerboy
Zeeland, MI
Posted: 02/07/19 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
Uncle Howard’s Kits
To bad his the plan links don't work.
Dan
2019 Chevy crew LTZ 2500 HD Duramax
2017 Wildcat 29rlx fifth wheel
Big Katuna
Deland, FL
Posted: 02/07/19 04:41pm Link  |  Quote  |  Print  |  Notify Moderator
Uncle Howard’s Kits
Dan
I didn’t click on any pictures.
Makes me think he’s defunct. I’d found it years ago.
* This post was edited 02/07/19 05:11pm by Big Katuna *
hbillsmith
www.RVroadtripper.com
Posted: 02/08/19 08:54am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all of your input! We do understand HOA guidelines as we currently live in a HOA restricted area, and truly appreciate the rules as it helps maintain our home value. We do believe that a small community built exclusively with RV Garages/RV Ports in far North Dallas where there is a HOA with restrictions would be successful for all of us RV/Motorhome owners. It would be built on the premise of the over-50 senior communities, but with RV garages. We are not opposed to purchasing a small residential lot and building our own RV garage home, however, this is difficult to find. If we found a residential lot in an established community, the building restrictions would most-likely not allow this type of home. Keep your suggestions coming, if you live in the North Dallas area, let us know your thoughts!
Wildcat2016-295rsx GMC2015-2500HD-DblCab D'max/Allisn+4x4 6.6'Bed
Maxxis235/80/16E;Andersen Ultimate2+4"offset;Airlft1 WirelessComp;GroundCtrl3;MorRyde RubbPinBox+CRE3000;3-Slidecovrs;Champion3100w/DIY ExtndRun;10'Portabote+5hp;Furrion48cam
Visited States
fred42
Charlotte, NC, USA
Posted: 02/08/19 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
Are these attached RV garages usually climate controlled? You could set that zone to 40 degrees and never winterize again.
Ralph Cramden
Not on this rag of a forum
Posted: 02/08/19 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
It's not so much the building restrictions already in place a lot of times, as much as it is the busy body NIMBY's who have nothing better to do than spew their rancid spunk at zoning or planning commission meetings. All in an attempt to dictate what you do on your property. You have to keep going further and further away from the populated madhouse areas to avoid those morons.
gemsworld
Arizona West Coast
Posted: 02/08/19 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
My RV garage has central air and heat because it was a model home, but most don't in areas that don't have freezing temps.
IdaD
Idaho
Posted: 02/08/19 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
In most of the country a garage attached to a heated home won't generally get cold enough to require winterizing a camper parked inside during the winter.
2015 Cummins Ram 4wd CC/SB
westernrvparkowner
montana
Posted: 02/08/19 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
Heating a garage in a cold weather area is much more expensive than having your RV professionally winterized and then de-winterized. And 40 degrees does not provide enough safety margin should the power go out and your heating system shuts down for even a short period of time. It is usually recommended that heat be set to a minimum of 50 degrees when leaving a home unattended in cold climes.
blofgren
Surrey, B.C.
Posted: 02/08/19 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
x2. It's simply not worth the risk to not winterize.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, RAM 20k sliding hitch, Retrax, Linex, and a bunch of options incl. cargo camera
