todd j
pride,la.
I have some delamination on the rear of my 2009 Sierra by Forest River. I have seen videos on injecting epoxy and clamping to remove bubbles. I'm not sure how well that would work on mine. What would I need to use to replace the entire back panel of camper? Should I use the Filon sheet? I repaired the leak that caused this just trying to decide which route to go to fix bubbles. Any ideas, suggestions???
Thanks for your help
ScottG
Bothell Wa.
Are you sure it was lamintaed to start with?
Many trailers are laminated everywhere but the back wall so they can run a bunsh of wires through it. My Forest River Wildcat was an example.
The back wall was a bit wavy and would move if you pressed on it.
Scott
Scott, Grace and Wesly
2018 Silver Fox 32A.
H0NDA eu2000i
JIMNLIN
Oklahoma
First thing is determining if the outside skin is bonded to a honeycomb structure or bonded to luan sheeting.
My 5er in sig had a small area on the side upper front corner that the filon had delamed (2' area) from the luan backing. I drill holes in the filon per service guys recommendations and injected adhesive he gave me. The trailer sat in a barn so I was able to use the side of the barn to jack a piece of plywood against the work area.
I haven't done a google/youtube on the subject but there should be lots of input on delam issues and how each job was done.
Ralph Cramden
US
JIMNLIN wrote: First thing is determining if the outside skin is bonded to a honeycomb structure or bonded to luan sheeting.
Short of a fiberglass cap, the rear wall is usually nothing more than filon laminated to a 1/8" thick piece of hardboard, more or less dense cardboard like used on the front curl, and the only thing that holds it in place is the corner trim and windows. It just floats / hangs there over the framing. Despite the sidewalls being an aluminum framed laminated panel, the rear wall is most likely framed with 2x2 wood studs. That's why the rear walls on a lot of new trailers look like the ocean if looked at from a sharp angle. Very few manufacturers who make laminated trailers use a true laminated panel for rear or front walls.
Super_Dave
Harrisville, UT
Is a small delam anything more than just cosmetic?
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 2003 Jetcraft 2125 - Yamaha 150 HP & 8 HP Kicker
Keithk3628
Jacksonville Florida
Todd
ScottG is correct, make sure the back wall is supposed to be glued. My Outback was loose as could be and I never noticed it until we traded it in and I was washing it to tow it in for trade-in. I just told the salesman on drop off expecting a change of agreed trade in value and was sure we would take a 2-3000 dollar hit.
The salesman told me upon inspection they appreciated our honesty but not to worry because they were never glued back there on the Outback, he said a lot of trailers were like that.
So check and make sure it is supposed to be glued/bonded back there.
Keith
