RV.Net Open Roads Forum: Tech Issues: Dometic New Generation refrigerators
 > Dometic New Generation refrigerators
Travelin2
SW Florida
Posted: 02/08/19 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
I bought the exact model, Dometic 2652. I figured that way I was more likely to not need to alter the gas line, Everthing is sure to fit and I can rob lots of good spare parts from the old one that should work on the new one.
John & Gloria
South West, Florida
2002 Bigfoot 25B21RB
2012 Avalanche Black Diamond LTZ 4x4
HadEnough
Traveling. Always.
Posted: 02/08/19 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
The only way to have more interior volume and the same exterior volume is to reduce the insulation volume.
They may be using more efficient insulation
marcsbigfoot20b27
Phx
Posted: 02/08/19 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
Replaced the failed 2652 cooling unit in my 2000 Bigfoot in 2014. Went with the Amish new cooling unit and it performs.....33 degrees in 115 ambient in Phoenix. I did add internal fin fans and fans up at the top exit on the roof.
Travelin2
SW Florida
Posted: 02/09/19 04:03am Link  |  Quote  |  Print  |  Notify Moderator
I would have replaced just the cooling unit but the interior of the refrigerator compartment was all yellowed so we wanted to eliminate that.
Travelin2
SW Florida
Posted: 02/09/19 07:37am Link  |  Quote  |  Print  |  Notify Moderator
Here's the part I bought to fix my problem...
filrupmark
Richmond,Texas
Posted: 02/11/19 06:37am Link  |  Quote  |  Print  |  Notify Moderator
Our RM2652 Would struggle in the Texas July and August heat. We went with a 10 cu.ft. Frigidaire residential. DW is very happy . Much roomier and cooling is great.
2004 Ford F250 Super Duty 6.0 Diesel, Bilstein 4600 Shocks, 16K B&W Patriot, Michelin M&S
2014 Augusta Flex AF34RS Trailair Tri Glide pinbox,
JT Strong Arms , Bridgestone R250'S, KYB Monotube Gas shocks
Finally a smooth ride !!!
