RV.Net Open Roads Forum: Tech Issues: Is an RV generator worth it?
 > Is an RV generator worth it?
Page of 8
2oldman
Salton Sea
Posted: 02/08/19 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
CoeyCoey wrote:
24 volts.
Will you be running the inverter at 24 then ? Reason I ask is that even with higher voltages you need to be concerned with wire and connections heating up when running high wattages for long periods.
I run mine at 50 volts, and had to double-up the positives due to heating after about a half-hour. Some of that heat could have been due to too-small bolts on the busbars however.
Big Katuna
Deland, FL
Posted: 02/08/19 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
My vote is get it fixed.
My Kharma ran over my Dogma.
CoeyCoey
Colorado
Posted: 02/08/19 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
2oldman wrote:
CoeyCoey wrote:
24 volts.
Yes. The max load should be less than 2,500 watts which would be about 116 amps from the batteries. With 4 batteries, that is only 29 amps from each battery. I won't need to worry about heat build up at all. However, I will be using the Tesla modules built-in temperature control system for warming the batteries on cold days.
LittleBill
Scranton, PA USA
Posted: 02/08/19 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
how will you be doing that?
the heat is generated by stalling the tesla drive motors, which then pumps that coolant to the battery's?
MrWizard
Traveling
Posted: 02/08/19 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
Pay CW for generator service
i do my own oil changes and have over 3000 hrs on the generator
on the avg, i change the oil every month
but not everybody is full time, or uses the Genny as much as I do
Radiate The Happy
1997 F53 Bounder 36s
road-runner
Oregon
Posted: 02/08/19 03:08pm Link  |  Quote  |  Print  |  Notify Moderator
If I were in that situation I'd at least investigate if I could safely shoehorn a Honda eu3000i or its Harbor Freight clone into the same compartment. It would take a lot of due diligence with respect to exhaust and cooling, but if it was feasible I'd consider it a superior solution.
2009 Fleetwood Icon
CoeyCoey
Colorado
Posted: 02/08/19 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
A water pump and an inline heater.
2oldman
Salton Sea
Posted: 02/08/19 03:19pm Link  |  Quote  |  Print  |  Notify Moderator
CoeyCoey wrote:
With 4 batteries, that is only 29 amps from each battery. I won't need to worry about heat build up at all. .
At 116 amps I think you'll need substantial wiring to the inverter. That's what I'm talking about, not the batteries.
LittleBill
Scranton, PA USA
Posted: 02/08/19 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
so your just using the coolant tubes is what you meant? i thought there was some 3rd party module that tied into module on the board.
CoeyCoey
Colorado
Posted: 02/08/19 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
10 gauge wire for 29 amps, 2 gauge if I had 116 amps through one wire, but I don't plan on doing that. They have charts which tell me what wires to use.
Page of 8
