RV.Net Open Roads Forum: Tech Issues: Furnace Noise
 > Furnace Noise
Lar's
Traverse City, MI
Posted: 02/08/19 08:03pm Link  |  Quote  |  Print  |  Notify Moderator
Anyone have any fool proof way to limit the noise I get from my furnace? Our friends furnace runs in their 5th wheel and is very quiet; ours sounds like a blast furnace. It's located under the stairs but not buried too far toward the front
Any suggestions appreciated.
Lar
2015 Dynamax Trilogy
36 RL
Ram 3500 Dually
MrWizard
Traveling
Posted: 02/08/19 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
you will get all kinds of replies
but NO, there is not much you can do with the existing furnace to reduce noise, blocking filtering or slower fan, will cause overheating in the furnace
you can try replacing it with the same model the your friends have
that 'might help' or you can buy the same RV they have
or switch to portable electric heaters
Radiate The Happy
1997 F53 Bounder 36s
Lar's
Traverse City, MI
Posted: 02/09/19 07:27am Link  |  Quote  |  Print  |  Notify Moderator
Thx ... I know the market is coming out with a Aqua Hot type prototype but think it's only sold to manufacturers and installed by them... I know they're quiet as we've had that before in a MH. I'm with you in that we'll just have to live with it.
SteveAE
Bend, Oregon
Posted: 02/09/19 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
I too dislike the noisy, inefficient, furnace.
So I mainly just use it for quick warm-ups and then use a catalytic heater (Olympian Wave 6) for the bulk of my heating needs. Opinions differ on catalytic/portable propane space heaters, so do your homework before buying one if that is what you choose to do.
Lar's
Traverse City, MI
Posted: 02/09/19 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
We too are big fans of portable heaters and have used them a lot, but... since we're here in AZ Valley and are paying electric... we get buy with more propane and less electricity... but when on the road... it's Katie Bar the Door.
Thx
Lar's
Traverse City, MI
Posted: 02/10/19 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
That Olympian Wave 6 looks pretty interesting... wonder how close to flammable materials It can be mounted? Worth another look I guess.
pnichols
The Other California
Posted: 02/10/19 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
Don't forget that unless you want to rapidly go through those little expensive green 1 lb. propane bottles - the portable propane heaters require you to probably have a non-metal hose (made of some kind of flexible material that can eventually degrade) carrying propane within the coach's living area, along with a connection on each end of it that can potentially start leaking someday.
The above presents way more of a risk than the rigidly mounted metal tubing/plumbing that is used by the RV manufacturers to feed propane to the cooktop, the oven, the furnace, the water heater, and the refrigerator.
We refuse to use a movable propane appliance inside the coach area, just in case.
* This post was edited 02/10/19 05:30pm by pnichols *
Phil, 2005 E450 Itasca Spirit 24V
doxiemom11
Arizona
Posted: 02/10/19 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe your furnace needs a little cleaning and maintenance. Adjustments for air/propane mix. Shouldn't sound like a blast furnace.
Lar's
Traverse City, MI
Posted: 02/11/19 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
Cleaning and adjusting makes sense... this spring or when the WX warms enough so I don't have to run the bugger every night.
Lar's
Traverse City, MI
Posted: 02/11/19 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
OH I understand the ramifications of having an open gas heater inside... with no vent either so air exchange becomes an issue... many can be hard plumbed if tolerances permit... I'm still really on the fence with them, though I do have one in my home as a backup in case of a power outage in winter.
 > Furnace Noise
