RV.Net Open Roads Forum: Need Barn clearance - will airbags help - Gasser
 > Need Barn clearance - will airbags help - Gasser
Txsurfer
Posted: 02/09/19 07:37am Link  |  Quote  |  Print  |  Notify Moderator
I bought a new place with a barn with 12' doors - My gasser is 12'2" to the top of the rear AC ( front clears ) - back does not due to rake. Fuel tank is full. I have been told to add airbags but I don't see how this will help with leaf springs on a Ford chassis? Will it?
2017 F250 PSD 4X4
2015 Livin Lite Axxcess 24FBA
2016 Honda Pioneer 1000-5 Deluxe
wolfe10
Posted: 02/09/19 08:18am Link  |  Quote  |  Print  |  Notify Moderator
Sorry, don't think I am getting the picture.
Air bags can only RAISE the coach meaning you will need MORE clearance.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
htss
Colorado
Posted: 02/09/19 08:43am Link  |  Quote  |  Print  |  Notify Moderator
Is it the garage door or the opening that is the problem? You might be able to put in a different door to get more clearance, if the door is the problem.
2012 Chevy 2500HD DA - 2009 Open Range (33.5' fifth wheel) - B&W Companion - 40 gallon aux tank - Myself, wife and two kids
TANDDANDBIGE
W. Wa. State
Posted: 02/09/19 08:54am Link  |  Quote  |  Print  |  Notify Moderator
my barn with a gravel floor was not tall enough so I "lowered" the floor on one side and built bulkheads around that area. Not elegant, but functional. Coach stays inside when not in use. TB
2002 HR ENDEAVOR 40'
2007 FORD EDGE TOAD
DrewE
Vermont
Posted: 02/09/19 08:57am Link  |  Quote  |  Print  |  Notify Moderator
Air bags (as in air helper springs, like Ride Rite ones et al.) will not lower the suspension on the gas motorhome unless other changes are made at the same time, which probably would be inadvisable. Obviously replacing the entire suspension with an air suspension is a different story.
Maybe you can get and install a lower profile air conditioner? Maybe if the ground isn't perfectly level you could fit in if you back in vs. pulling in head on (or vice versa)? Maybe you could lower the floor of the barn, or raise the building up by a few inches on its foundation?
rgatijnet1
Posted: 02/09/19 08:59am Link  |  Quote  |  Print  |  Notify Moderator
How often do you go in and out of the garage? It might be easier to just take the cover off of the rear AC when you move the RV. The alternative is to let the air out of the rear tires and then reinflate them after you have passed the door opening.
Due to the rake of your coach, air bags MAY HELP if raising the front end will lower the rear end. This can be easily checked by looking at the location of the rear AC in relation to the rear axle. If it is over the rear axle, raising the front will not help. If it is well behind the rear axle, it may help and you can check this by putting a jack under the front axle and by jacking the front end up, you can measure how much the rear drops. I seriously doubt that the air bags will help your situation.
wanderingaimlessly
SOBOVA
Posted: 02/09/19 09:31am Link  |  Quote  |  Print  |  Notify Moderator
Let some air out of the back tires go in.
OR
IF it is an overhead door you can sometimes push up an additional inch or two past where it will stay on its own. In that case cut a length of pipe an inch longer than your rigs is tall, and use it to prop up the door when entering or exiting.
ItsyRV
Desert SW
Posted: 02/09/19 11:56am Link  |  Quote  |  Print  |  Notify Moderator
OR
This /\, if you have a rollup.
If the physical door opening hole is more than the door's stay up height, that would be my first choice. Just push and prop it up past the hanging stay-up and you have the clearance you need.
Letting air out of the tires is a good second choice.
However, since you mention the rake of the roof, not sure why one end goes in and the other does not.
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
Terryallan
Foothills NC
Posted: 02/09/19 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
Agree. If the floor is NOT cement, or asphalt. Scrape it down. Other than that. Raise the door opening
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Wherever I happen to park
Posted: 02/09/19 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
I have no clue why anyone would think Air bags will help.
You can raise the header on the door
Or you can lower the floor
Or you can load 'er down.. If you put enough weight in the RV it might loose 3 inches.
BUT DANGER.. If you unload the RV..... it goes back up.. I know of semi drivers who have driven under a birdge ....loaded... dozens of times but the first time under that low bridge deadheading.> CLANG and here come da judge.
Home is where I park it.
