RV.Net Open Roads Forum: Class A Motorhomes: Induction cooktop
 > Induction cooktop
Ivylog
Blairsville, GA and WPB, FL.
Posted: 02/12/19 05:47am Link  |  Quote  |  Print  |  Notify Moderator
On another forum an induction question got me to check if my recently installed 2 burner Cuisinart was drawing power all of the time. We dry camp often in the summer so every amp counts. Turns out it draws 3 amps DC even when not using. Over 24 hours that’s a lot of wasted power. I may have to add a remote switch to make it easier to turn it off at the outlet.
08 HR Navigator 45'
Sold 04 Dynasty after 14 great years.
[url=https://i.
wildmanbaker
Kennewick, Washington
Posted: 02/12/19 12:13pm Link  |  Quote  |  Print  |  Notify Moderator
Are you sure its the burner that's drawing the current and not your inverter? 3 amps sounds like what the inverter draws at idle.
Wildmanbaker
Ivylog
Posted: 02/12/19 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
Positive...amps went from 10 to 7 when I unplugged it. Checked it two times.
You do not need induction cookware...anytime magnetic will work including most SS pots and pans.
MrWizard
Traveling
Posted: 02/12/19 03:36pm Link  |  Quote  |  Print  |  Notify Moderator
Steel is inductive, it's just not labeled as induction cookware
All induction cook ware is some form of steel or iron
Radiate The Happy
1997 F53 Bounder 36s
Wherever I happen to park
Posted: 02/12/19 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
My Portable induction burner came with a "Refrigerator Magnet" and the manual says if it sticks it cooks.
Now.. Stainless.. Some sticks. some it does not.. But on Cast Iron or regular steel it does. "Copper Cookware" (TM) pans it works T-Fal some do some do not. Just take a magnet with you when you go shopping.
Home is where I park it.
wildmanbaker
Posted: 02/12/19 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
WOW! Thanks for the update. Our inverter pulled 3 amps at idle, and like you, we like to boondock in the spring, summer, and fall, so I disconnected it and changed the wiring.
Ivylog
Posted: 02/14/19 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
To switch the induction off...the plug is to far from the door to just unplug. I bought a $10 3’ 15 amp power strip with a switch. Mounted it just inside the door below the unit making it easy to turn it on/off.
DSDP Don
Moorpark, Ca
Posted: 02/14/19 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
Our new coach came with the True Induction Cooktop, which is a 110 volt unit. We have 8 AGM batteries and the cooktop will operate off of the inverter. Even though it does, I've never been a fan of running the cooktop or microwave off of the inverter. I always fire up the generator.
* This post was edited 02/15/19 05:10pm by DSDP Don *
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2016 GMC Canyon 4WD Crew Cab
zb39
slippery rock
Posted: 02/15/19 11:14am Link  |  Quote  |  Print  |  Notify Moderator
Thank you all!!
Tiffin Zephyr(sold)
2017 Host mammoth, sold
49 states, 41 National Parks, 7 Provinces
2019 2 door Rubicon 6 spd.
2019 Berkshire XLT 45B
 > Induction cooktop
