RV.Net Open Roads Forum: Class A Motorhomes: Induction cooktop
 > Induction cooktop
zb39
slippery rock
Posted: 02/09/19 08:14am Link  |  Quote  |  Print  |  Notify Moderator
Does an induction cooktop run off of the inverter or is it genset only if not plugged in.
I am referring to a cooktop in a large DP. Tiffin, Newmar, or Berkshire.
thanks
Tiffin Zephyr(sold)
Artic Fox 1150 slide(sold)
2011 DRW 3500 Crewcab Longhorn( sold)
2016 RAM Laramie Limited DRW crew cab(sold)
2017 Host mammoth
49 states, 41 National Parks, 7 Provinces
2018 RAM 5500 CM bed
2019 2 door Rubicon 6 spd.
DrewE
Vermont
Posted: 02/09/19 09:01am Link  |  Quote  |  Print  |  Notify Moderator
It would depend on how beefy the inverter (and battery bank supplying it) are, I suspect. It may be necessary to have a 240V inverter in some cases. Most or all of the RV-specific designs are 120V I think, so it would just be a question of having sufficient power available to run it, similar to a microwave.
San Simeon area, California
Posted: 02/09/19 09:12am Link  |  Quote  |  Print  |  Notify Moderator
Would need a bunch of batteries if you weren’t plugged in.
2015 Winnebago 2101DS TT & Tahoe LTZ, 300 watts WindyNation solar-parallel & MPPT, Trojan T-125s. TALL flagpole for US flag. Prefer USFS, COE, BLM, NPS, TVA, USF&WS, state & county camps. Bicyclist! 14 year Army vet - 11B40 then 11A - old MOS 1542 & 1560.
MrWizard
Traveling
Posted: 02/09/19 09:56am Link  |  Quote  |  Print  |  Notify Moderator
Assuming there is a whole house inverter, then yes there would be power
To it
The question becomes , how much battery is available aka how much cook time at what power level
Ask for a demo, have them show you
This really isn't an issue, unless you like to cook long elaborate meals late at night when not allowed to run the generator
For. normal meal times, does it really matter if you need to run the generator for 10 to 30 minutes
* This post was edited 02/09/19 12:11pm by MrWizard *
Radiate The Happy
1997 F53 Bounder 36s
dougrainer
Carrolton, Texas
Posted: 02/09/19 11:46am Link  |  Quote  |  Print  |  Notify Moderator
Tiffins do NOT run off the Inverter. Doug
MrWizard
Traveling
Posted: 02/09/19 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Doug
Wherever I happen to park
Posted: 02/09/19 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
thanks
YOu need to be a touch more specific.
ON MY RV I use a portable INduction cooktop and it works fine on the TRUE SINE inverter. or generator or shore power
IF you are talking about an INSTALLED.. INduction cooktop (Instead of a gas range like I have) You will need to Read the fine manual or just try it and see.
I also don't know how they handle MSW. (and have no wish to find out).
Home is where I park it.
Big Katuna
Deland, FL
Posted: 02/09/19 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
He doesn’t have the RV yet.
My Kharma ran over my Dogma.
MrWizard
Traveling
Posted: 02/09/19 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
i would say he is between RVs and looking at the Tffin
theoldwizard1
SE MI
wa8yxm wrote:
You need to be a touch more specific.
On my RV I use a portable Induction cooktop and it works fine on the TRUE SINE inverter or generator or shore power.
I know if I buy another TT, I will ask for a propane DELETE ! 1000w-2000W PSW inverter, probably four 6V golf cart batteries and a 2000W generator (or maybe 2) and you should be all set.
Boondocking would require some good solar and generator use for hot water and to be sure the batteries were up for the evening. Good insulation and heated mattress pad will get you through most cool nights. If you boondock below freezing, you will still need a propane furnace. Non-vented propane heaters release too much moisture to be run overnight.
 > Induction cooktop
